I am using the following circuit for power oring
1. when battery only connected... Voltage supplied by battery
2. when battery is connected and yet 9V supply is connected, the battery gets disconnected and the power source is 9V battery
This is working fine
But when I connect load and say that load draws more current (3A for example)
and I have DC jack (Adaptor) and battery connected, it works fine
But if I disconnect the battery, the adaptor alone is not able to supply enough current
I am using 9V/3amp adaptor
My question is "When both are connected, Is the power still taken from battery, if so why??"
Am I missing something in the circuit that it is behaving like this
