voltage level converter for MCUs
Noman Yousaf
Full Member level 4
Lahore Pakistan
hi all,
i want to control a shift rgister whish is CMOS(4015 or 4094).the circuit is supplied
12 volt.
i want to give the data and clock by AT89C51 MCU. That works on 5 volts.
how can i interface both circuits.i can not reduce the voltage of shift register circuit . i think i have to use voltage level converter which can convert 5volts logic level to 12 volt logic level.
please tell me about this
thanks for this link
i used transistors (as common emmitor mode)but beacuase of saturation of level, these did'nt work on hi speed.
is there any circuit of level converte which has op-amp or somthing? may be 4504 is not available in our country
Here is a circuit which converts from 3V to 5V logic ..
If you would like to convert level from 5V to 12V the suggested resistor values would be around 2kΩ ..
Regards,
IanP
Reactions: iffe
    iffe
A good solution can be to use a digital optpcoupler with open collector.
Bye
