Dear All,
Is there anybody who can provide me an explanation why is not recommended to place only a series resistor when I want to connect a voltage regulator with 3.3 Volts and reduce the voltage up to another component to 2.8 Volts ?
People just say I shall use a voltage divisor instead, because only a series resistor would consume a lot of current I can burn the component. The component is an IC that works with 2.8 Volts and consume only 50uA.
If true, how to understand that only one resistor is not possible, since the R = 3.3 V - 2.8 V / 50 uA
Please advice.
