Abhishek_Anand
Newbie level 5
- Joined
- May 28, 2013
- Messages
- 9
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,379
I am using a 10W solar panel for a sun tracker project. I need to monitor the power at regular intervals.
But the voltage across the panel drops when I connect the load. The drop is in the range of 15V to 4V/5V.
The load that i am connecting is 2 10W resistors of 75ohms in parallel i.e 37.5 ohm in effect.
This value was chosen to match the characteristic resistance of the panel. **broken link removed**
I used the closest value I could find, actual value is 30 ohms approx.
The ratings of my panel are : 10W, 36 cells, Voc = 21.5V, Isc = 0.6A, Vp = 17.5V, Ip=0.58A
Is there a way i can minimize this drop?
