[SOLVED] Voltage doubler with voltage regulator
aurelien_7
Newbie level 5
Newbie level 5
hi!
I need 18 volts supply, since i'm having 12 volts transformer i decided to use full wave voltage doubler to raise voltage to 24 volts.
But at the output of doubler i'm getting 36 volts :/ and after pluging it to LM7818 at the output of regulator i'm getting 3.5 volts :(
In datasheet of LM7818 maximum input voltage is 33 volts!
So i don't know beacause of the fact that input voltage is exceeding maximum input voltage rated by datasheet I am wierd output from regulator.
So I am open for advices :)
What you say on this circuit :
Dont expect to much current from your design, and BradtheRad is right you need bigger capacitors.
:wink:
