I have a test instrument which produces the output voltage of +4.8V. I want to increase this voltage to +5.8V and I cannot use boost converter because when the 4.8V starts to decrease, the voltage +5.8V should also starts to decrease. I have doubled the voltage using LMC7660 voltage converter and reduces the voltage using voltage divider network. Attached is the circuit for the reference.
But the problem is, when I test the circuit with a voltage source of +4.8V, it works good. But when I connect it to the test instrument it is not working. Please help to solve this issue.
