skatamatic
Newbie level 2
I need to design a circuit that uses some sort of transistor to control resistance.
Here's some background info...
I have a DAQ system that monitors a wireless pressure sensor. The information received from the sensor is digital, and we use it in our software to record charts/etc. Our customer asked that we supply an analog output with our system to allow him to hook it into a 3rd party monitoring system if need be. The 3rd party monitoring system is looking for a 4-20mA signal. I used a digital to analog converter module (an ADAM 6024) to output between 4 and 20 mA based on the 0-10000PSI reading from the pressure sensor. It has come to my attention, however, that this signal will not work for them. There are 2 terminals that they are to tie into on our system (AO+ and AO-), but I found out that on the AO+ terminal they are actually sending us 12VDC (as if they were trying to plug into/power a pressure transducer) and expecting a signal on a return/ground wire. This does not work, the ADAM6024 does not like getting voltage pounded into its AO+ terminal (as you can tell, I am no electronics guru haha).
So here's what I need:
A device that takes a -10 to 10V control signal (or anything within that range) and when there is 12VDC connected to its output 'supply' the device's resistance is changed (based on the control signal) to make the output current 4-20mA. Note that we do NOT have access to their ground, only a 12VDC power in and a signal out.
I looked into using a photocell design to do this, but would much prefer to use a transistor of some sort. I hope this is possible. ANY help or a push in the right direction is welcome. Keep in mind I am a bit rusty on my transistor physics (although I am not electronically inept) so keep things in laymen terms if you can!
