Voltage amplifier model (excercise question from Sedra Smith 5th ed.)
peterpops
Junior Member level 3
Sweden
Hi!
I'm doing some exercises in Microelectronic Circuits (Sedra Smith 5th ed) and got stuck on 1.13 (voltage amplifiers)
NOTE! This is not the end-chapter excercises included in the PDF solution manual!
According to SedraSmith a voltage amplifier can be modeled as in the figure.
The question is:
"An amplifier with a voltage gain of +40 dB, an input resistance of 10kΩ, and an output resistance of 1kΩ is used to drive a 1-kΩ load. What is the value of Avo? Find the value of power gain in dB"
The answer in the book is:
"Ans. 100 V/V; 44 dB"
My solution:
I know
Voltage gain in dB = 40, which means 40 = 20 log(Av) => Av = 100
EQ.1: \[{A}_{v}=\frac{{v}_{o}}{{v}_{i}}=100\]
Voltage division gives me \[{v}_{o}={A}_{vo}{v}_{i}\left(\frac{{R}_{L}}{{R}_{L}+{R}_{o}}\right)\]
rewritten \[{A}_{vo}=\left(\frac{{v}_{o}}{{v}_{i}}\right)\left(\frac{{R}_{L}+{R}_{o}}{{R}_{L}}\right)=100\left(\frac{{R}_{L}+{R}_{o}}{{R}_{L}}\right)\]
From here I can go 2 ways:
1. Since I know Ro and RL I just substitute them in the equation above and the answer is \[{A}_{vo}=100\left(\frac{1000+1000}{1000}\right)=200\]
Or
2. Avo is the "open-circuit voltage gain" which means I assume that RL is infinite which gives me \[{A}_{vo}=100\]
Since the answer is 100 V/V I assume solution 2 is the correct one.
Now over to the second part of the question, the power gain in dB.
The current through Ri is (with the help of EQ.1) \[{i}_{i}=\frac{{v}_{i}}{{R}_{i}}=\frac{{v}_{o}}{{100R}_{i}}\]
The current through Ro is \[{i}_{o}=\frac{{v}_{o}}{{R}_{L}}\]
Which gives me the current gain \[{A}_{i}=\frac{{i}_{o}}{{i}_{i}}=\frac{\frac{{v}_{o}}{{R}_{L}}}{\frac{{v}_{o}}{{100R}_{i}}}=\frac{{100R}_{i}}{{R}_{L}}\]
With values inserted Ai = 1000 A/A
Power gain, Ap = Av*Ai and depending on which voltage gain solution above
Ap = 200 * 1000 = 200000, or Ap = 100 * 1000 = 100000
in dB the power gain is either = 10*log(200000) = 53dB, or = 10*log(100000) = 50dB
So where did I go wrong or is the SedraSmith answer incorrect?
Thanks in advance
/P
The way I would have solved this would be:
Vo=(Vi*Av0)/2
100*2=Av0
Av0(dB)=20*log(200)=46 dB
You give the input resistance, but that's irrelevant since it's assumed Rs is zero. Perhaps you left out that bit of information??
Vo=(Vi*Av0)/2
100*2=Av0
So you agree with solution 1?
Is the power gain calculation correct? In that equation I use the input resistance.
I think the solution is quite simple:
1st question:
40 dB is the gain of the amplifier alone ("An amplifier with a voltage gain of +40 dB") then Avo=10^(40/20)=100V/V
2nd question:
The power gain is given by Pout/Pin then we need to calculate input and output power.
Pin=Vin²/Ri
Pout=Vout²/RL
Vout=Avo*Vin*RL/(Ro+RL) thus:
Pout=[Avo*Vin*RL/(Ro+RL)]²/RL that is:
Pout=(Avo*Vin)²*RL/(Ro+RL)]²
Then:
Pout/Pin=Avo²*RL*Ri/(Ro+RL)² or, in dB
Pout/Pin(dB)=10*Log[Avo²*RL*Ri/(Ro+RL)²]
Numerically
Pout/Pin(dB)=10*Log[100²*1000*10000/(1000+1000)²]≈44 dB
1st question:
2nd question:
Pin=Vin²/Ri
Pout=Vout²/RL
Then:
Numerically
Thank you for the answer, two questions.
1. Do you use the fact that Avo = "Open-circuit voltage gain" so RL is assumed infinity i.e. Avo = Av = 100 V/V (or 40dB)?
2. Can you explain why my answer to question #2 is incorrect?
Power gain = Pout / Pin
Pout = Vout^2 / RL
Pin = Vin^2 / Ri
same as you, but then I want to use Av = Vout / Vin = 100 (since this info is given for the current system or Rs/Ri/Ro/RL)
so I get Pout / Pin = (Vout^2 / RL) / (Vin^2 / Ri) = (Vout^2 / RL) / (Vout^2 / (10000 * Ri)) = 10000Ri / RL = 100000 W/W or 50dB
I read you answer: you forgot the output divider RL/(Ro+RL).
The total voltage gain is Av=Avo*RL/(Ro+RL)
The input current is Iin=Vi/Ri while the output current is Iout=Avo*Vi/(Ro+RL)
Then the current gain will be: Iout/Iin=Avo*Ri/(Ro+RL)
As you said Ap=Av*Ai thus:
Ap=Avo*RL/(Ro+RL)*Avo*Ri/(Ro+RL) that is: Ap=Avo²*RL*Ri/(Ro+RL)²
as per my previous post.
