VNA calibration methods using SOLT an TRL methods
mayavi
Junior Member level 3
ind
could anybody plz explain the VNA calibration using SOLT and TRL methods
I will assume you are familier with microwave engineering as a start
every network or system can be modeled by its S parameters
the vector network analyzer measures this matrix
this is done by feeding the network fom one port and measuring the reflection from the same port (Snn) and the transmission to other ports (Smn)
the problem is you want to subtract the effect of the feeding probes
this is done by calibration
here is a pdf explaining all methods of calibration
LaTeX Commands Quick-Menu:
