darcyrandall2004
Full Member level 1
- Joined
- Feb 1, 2009
- Messages
- 97
- Helped
- 3
- Reputation
- 6
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Perth, WA, Australia
- Activity points
- 2,099
Hello, I have an Advantest R3762 VNA which has an annoying feature of requiring the calibration data to be reloaded from a floppy each time the thing is started. I have decided that I wish to use an excel macro to calibrate the machine and store the results in an SQL database. I am currently in the process of writing the VBA logic but the attached extract from "Microwave Component Measurements" troubles me.
http://obrazki.elektroda.pl/8183532000_1355153284.jpg
Page 132, states that all VNAs have in built models for the reflection standards, Short, Open, Load. Basically I measure the standards, then the VNA compares the measured values with its inbuilt models to determine what sort of correction is required.
I will require these models if I am to write the calibration logic. Does anyone know where I can find the models?
What if I measure the standards attached directly to the VNA ports and take these values as the Actual reflection standards. Then I attach the cables and VNA reflection standards and determine the Measured reflections. From these measurements I can then determine the calibration error terms. What do you think? Would this be accurate?
Any better ideas?
Thank you
Any better ideas?
Thank you
