Virtuoso ADS Output Expression
teem
Junior Member level 1
Hello,
I setup below outputs to calculate the equavilent parallel R and L by doing one-port SP analysis in Virtuoso ADS.
freq=xval(aaSP(1 1))
Lp=-1/imag(YP(1 1))/(2*acos(-1)*freq))
Rp=1/real(YP(1 1))
It showed error message: ("*Error* eval: unbound variable" freq).
Seems the result of the 1st expression, freq=xval(aaSP(1 1)), can not be used in the following expressions.
Could any seniors tell me how can I solve it, i.e., let the results of previous expressions be used in the following expressions?
Thanks a lot.
freq. is not a defined variable in Virtuoso as in ADS.
Instead, use calculator and its functions to find these values..
