This script is used for automatically generating verilog instance from
the file. When you type the given hot-key, instance will be copied to
system clipboard, and display or not by its working mode. Once your
file can access syntax check, this plunin will work, or there must be a
bug. It's encouraged to share it with me and all other people.
Supported working mode:
mode 0(default):
copy inst to clipboard and echo inst in commandline
mode 1:
only copy to clipboard
mode 2:
copy to clipboard and echo inst in split window
mode 3:
copy to clipboard and update inst_comment to file
To change the default working mode, you should modify the line "let
g:vlog_inst_gen_mode=x", x is the default working mode.
User defined command:
VlogInstGen : generate verilog instance
VlogInstMod : change working mode
Default hot-keys:
,ig : VlogInstGen
,im : VlogInstMod
Newest version from:
https://www.vim.org/scripts/script.php?script_id=4151
