TQFP
Junior Member level 3
I have a circuit that drives a VGA monitor using a simple 4-bit (per color) resistor DAC. This works well, colors look great, image is stable, etc. However, I also see circuits in datasheets (like the typical use schematic from AD725) or on other boards that use buffer ICs or discrete transistor amp circuits. How do I know if I should be using something similar? Since my circuit is working fine, what would I gain by using something like an AD8073? Here are three examples of circuits that I have seen. Can anyone explain why/when you would use one over the other?
Thanks,
Matthew
Resistor DAC, similar to what I'm using. Works fine.
Discrete amp
Using a video IC
Thanks,
Matthew
Discrete amp
Using a video IC
