iruraz
Member level 2
- Joined
- May 4, 2009
- Messages
- 47
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- andromeda
- Activity points
- 1,602
Hi all,
I purchased Vicor 's Maxi converter module which output 's maximum value can be 13.2Vdc :
I intend to use it with 12Vdc lead-acid backup battery. If DC-DC converter 's output would be about 13.8-14.2Vdc , there is no problem about the design.
Now , I am confused about connection. How should I connect Vicor 's output with 12Vdc backup battery and load? As far as I know, DC-DC should hold battery voltage on charged value, it can be 12.8Vdc in this case.
What do you think about this solution (in the below schematic)?
There is a zener diode which is 12.8V and 5W.
Maximum current which is flow over Rs resistor:
Max. Cur = 5W/12.8V = 0.39A --> ~400mA
Minimum value for Rs:
Min. Rs = (13.2V - 12.8V) / 0.4A = 1 ohm
power dissipation for Rs:
P = (0.4A) x (0.4V) = 0,16W
In this case auxiliary (backup) battery behaves like a load until it charges. It charges between 0-400mA at 12.8V. I know it is very slow charging but time is not important for me in this application.
I would like to know your advices.
Regards.
Regards.
