FANT
Advanced Member level 1
- Joined
- Feb 27, 2002
- Messages
- 418
- Helped
- 52
- Reputation
- 104
- Reaction score
- 37
- Trophy points
- 1,308
- Location
- Italy
- Activity points
- 3,689
A question that I cannot answer:
I have a PCB working on the microwave field; between upper and lower layer there are some vias that are used to continue the ground reference from bottom to upper layer.
If the vias are open, the current ( that travels on the surface, due the skin effect ) passes through the hollow tube made by the metallization of the via.
But what happens if the via is completely filled with copper ?
The upper surface is a continuous plane and it should not pass the current to the bottom plane.
But if I think on a DC frequency, the via filled with copper is a better solution for resistance.
Help please.
Thank you
Mandi
Help please.
Thank you
Mandi
