via between signal layer and plan layer in Altium
alibarghi
Member level 2
Member level 2
How to switch and place via between signal layer and plan layer in Altium?
I switch between signal layers with "*" ; How do I switch between all layers(plane and signal)?
Are you trying to use buried or blind vias?
You dont have to switch between layers to place a via. In via properties , you can edit the via stackup or you can also edit the start and stop layers to make it burried/blind
You have to enable desired layers first.
Yes it is enabled
Yes it is true, But this is a general way to create via between any layers, I am looking for a quick way to do it.
If you use all the vias in same fashion, you can change via defaults in DXp prefrerences.
Or use PCB Inspector panel to modify multiple vias.
thanks your replies.
I'm currently using this method but I tend to create a shortcut or Rule for it.
