rmercury
Newbie level 1
- Joined
- Mar 22, 2014
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 15
I am new to VHDL, but have been programing multiple other languages for years. I've been reading a few textbooks and websites. I've also read through alot of the newbie posts here. I'm looking for any feedback on my code.
The point of this code is to communicate with a TLC5940 a PWM 16 LED driver. It requires a serial connection of 192 bits to control the LED intensity within 4096 clock pulses that the PWM of the chip.
The proper clocks are generated and data is output at the neg edge (so it will be ready at the positive clock edge.
I will be adding more code to generate the LED sequence and intensity.
Because I've never done VHDL I want to make sure that I'm updating the signals correctly and that real delays won't hinder my approach. (I have not simulated with real time delays or on the actual FPGA which is my next step). I also want to make sure that I'm not breaking any golden rules or doing it in a non efficient way.
Thanks for the feedback!
LIBRARY ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
ENTITY light_tester is
GENERIC(
pwm_pulses : integer := 10; --4096--number of spi slaves
transmit_pulses : integer := 5); --192--data bus width
PORT(
clock : in std_logic; --SYS Clock
gsclk : buffer std_logic := '0'; --GS Clock
dcprg : out std_logic := '0'; --DC Program (keep low) for future development
sclk : buffer std_logic := '0'; --Shift load clock
blank : out std_logic := '0'; --Blank outputs/zero PWM counter
vprg : out std_logic := '0'; --EEPROM Program (keep low) for future development
xlat : buffer std_logic := '0'; --latch new data use when blank is high
data : out std_logic := '0'); --data sent out
end light_tester;
ARCHITECTURE logic OF light_tester IS
begin
process (clock) --clocks pwm of TLC5940 using 1/2 FPGA clock freq (25 MHz => 12.5 MHz)
variable gs_counter : integer range 0 to pwm_pulses*2+3 := 0;
variable senddata : boolean := true;
variable data_to_send : std_logic_vector(0 to 7) := ('1', '1', '0', '1', '0', '0', '1', '0');
begin
if(clock'EVENT and clock = '1') then
case gs_counter IS
when pwm_pulses*2 => -- done with clocking in data
gs_counter := gs_counter+1;
blank <= '1'; --set blank high to reset the TLC5940 PWM counter
when pwm_pulses*2+1 =>
xlat <= '1'; --set xlat high to latch new data
when pwm_pulses*2+2 => --toggle xlat and blank and reset to start over
xlat <= '0';
blank<= '0';
gs_counter :=0;
senddata :=true; -- send new data next round
when transmit_pulses*2 => --last transmitted serial data so dont transmit any more
senddata :=false;
gsclk <= not gsclk; --toggle pwm clock
when others => --clock 4096 pwm pulses
if (senddata) then --only send data when you haven't transmitted all the bits
sclk <= not sclk; --toggle serial data clock
end if;
end case;
end if;
if (clock'event and clock = '0' and senddata) then --clock is 0 => load new data
data<=data_to_send(gs_counter); --load data to be transmitted
--right now this is just dummy data
end if;
end process;
end logic;
