VHDL template to infer Xilinx Distributed RAM
omara007
Cairo/Egypt
Hi folks
Is there any VHDL template or coding guidelines suggested by Xilinx to infer its Distributed RAM the same way they suggest some other templates for Block RAM inference ?
P.S. I don't want to use CoreGen as I want to keep everything in my VHDL code.
My device is Spartan-3A DSP
You can get your anwer from XAPP464 or use the following teplate:
component RAM16X1S
-- pragma translate_off
generic (
-- RAM initialization (“0” by default) for functional simulation:
INIT : bit_vector := X"0000"
-- pragma translate_on
port (
D : in std_logic;
WE : in std_logic;
WCLK : in std_logic;
A0 : in std_logic;
A1 : in std_logic;
A2 : in std_logic;
A3 : in std_logic;
O : out std_logic
end component;
Hope it helps,
Best regards,
/Farhad
    omara007
