VHDL SPI driver for AD5781
Hyrsut
Newbie level 3
Newbie level 3
I'm working with a Spartan 6 and I'd like to drive an AD5781. I've written a VHDL SPI-like driver but the DAC remain at 0V .... so there is a problem with my vhdl ...
Here my code, if you can take a look at it and tell me what is wrong - Thanks in advance :
library IEEE;
 use IEEE.STD_LOGIC_1164.ALL;
 use IEEE.numeric_std.all;
 entity AD5781 is
    Port (
 Sync : out std_logic; -- Signal de synchronisation
 Sclk : out std_logic; -- Horloge
 SDin : out std_logic; -- Données à convertir
 SD0  : in std_logic; -- Données de sortie (verification ou daisy chain)
 LDAC : out std_logic; -- Chargement de la valeur à convertir
 CLR  : out std_logic; -- Signal de clear
 Clk  : in std_logic; -- horloge fpga
 Data_in : in std_logic_vector(15 downto 0); -- Données d'entrée à convertir
 Addr_ok : in std_logic -- Validation de l'adresse
 end AD5781;
 architecture Driver of AD5781 is
signal Data_to_send : std_logic_vector(23 downto 0);
signal init : natural :=0;
constant max_count : natural := 1000;
signal Rst_n : std_logic;
signal Sclk_temp : std_logic;
begin
Rst_n <= '1';
Reception_donnees : process(Data_in, Addr_ok, init)
begin
	if Addr_ok='1' or init=1 then
		Data_to_send <= "0" & "001" & X"3fff" & "00" & "11" ; --  contient les data a envoyer
		--Data_to_send <= "0" & "001" & Data_in & "00" & "11" ; --  contient les data a envoyer
else
	if init=0 then
	--Data_to_send <= "001000000000000000010010";
	end if;
end if;
end process Reception_donnees;
generation_horloge : process(Clk, Rst_n)
variable count : natural range 0 to max_count;
begin
if Rst_n = '0' then
	count := 0;
	--Sclk <= '1';
	Sclk_temp <= '1';
elsif rising_edge(Clk) then
	if count < max_count/2 then
		-- Sclk <= '1';
		 Sclk_temp <= '1';
		 count := count + 1;
	elsif count < max_count then
		-- Sclk <= '0';
 		 Sclk_temp <= '0';
		 count := count + 1;
	else
		 count := 0;
		-- Sclk <= '1';
		 Sclk_temp <= '1';
	end if;
end if;
end process generation_horloge;
emission_donnees : process(Data_to_send, Sclk_temp, init, Clk)
variable i : integer :=23;
variable rep : integer :=0;
begin
LDAC <= '0';
CLR  <= '1';
if rising_edge(Sclk_temp) and i>=0 then
	Sync <= '0';
	SDin <= data_to_send(i);
	Sclk <= '1';
end if;
if falling_edge(Sclk_temp) then
		i:=i-1;
		if i<0 then
		Sync <='1';
		SDin <='0';
		else
			Sclk <= '0';
		end if;
		if i<-2 then
			i:=23;
			Sync <='1';
			SDin <='0';
		end if;
end if;
end process emission_donnees;
end Driver;
Well first of, data_to_send is always constant.
second, you cannot use both the rising and falling edge of a clock in FPGA. I suggest you synchronise everything to your system clock.
data_to_send is constant in order to debug this driver : it's for setting the dac output other than 0V.
Sclk_temp is syncronised with Clk using the generation_horloge process. In simulation and in reality it seems ok but how can i improve it ?
dont synchronise it. using a logic generated clock is a bad idea. I suggest using the system clock using sclk_temp as a clock enable.
You can use both edges, but can't assign the same signal on both edges in synthesizable HDL, as done in the present code.
But there's no reasonable purpose for dual edge clocking in this design.
I agree about the clock enable suggestion. SCLK should be the only generated clock in the design and not clock any internal registers.
I changed the design with this, but the dac still not working :
CLR  <= '1';
Sclk <= Sclk_temp;
if rising_edge(Sclk_temp) then
	if i>=0 then
	LDAC <= '1';
	Sync <= '0';
	end if;
		i:=i-1;
		if i<-1 then
		LDAC <= '0';
		Sync <= '1';
			if i<-2 then
			i:=23;
			end if;
		end if;
end if;
the code you posted is not valid VHDL, so you either copied it wrong or did not compile it.
