yttuncel
Junior Member level 3
Hello,
I've managed to solve the issues on my old topic, and here is a newer one. I want to scroll the text I've written on the seven segment display wrto clock, but system clock too fast. I tried to mux the clocks but I got multiple clocks error. Now I am trying to do it by counter. Here is the code:
The problem is when I toggle the pin of doShift, I get random characters on seven segment display. What is the error here?
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; use IEEE.numeric_std.all; entity my_shifter is port(clk : in std_logic; doShift : in std_logic;--input to determine shifting(0>shifts when a new char is available, 1>shifts 1 digit per second, no datains) Scan_Dav : in std_logic;--from keyboard, data is ready Data_in : in std_logic_vector (7 downto 0);--scancode O1 : out std_logic_vector(7 downto 0); O2 : out std_logic_vector(7 downto 0); O3 : out std_logic_vector(7 downto 0); O4 : out std_logic_vector(7 downto 0) ); end my_shifter; architecture bhv of my_shifter is signal bytes : std_logic_vector(63 downto 0):=(others => '0'); signal Scan_Dav_Sync: std_logic_vector(1 downto 0):="00"; signal Previous_Scan_Dav: std_logic:='0'; signal shift : std_logic:='0'; signal flag : std_logic:='0'; signal first_letter: std_logic_vector(7 downto 0):="00000000"; begin process(clk) variable var:integer range 0 to 50000000 :=0; begin if rising_edge(clk) then if var = 50000000 then var:=0; flag<='0'; shift <= '1'; else flag <= '1'; var:=var+1; shift <= '0'; end if; end if; end process; process (clk, doShift, flag, shift) begin case doShift is when '0' => if rising_edge(clk) then Scan_Dav_Sync(0) <= Scan_Dav; Scan_Dav_Sync(1) <= Scan_Dav_Sync(0); Previous_Scan_Dav <= Scan_Dav_Sync(1); if (Previous_Scan_Dav = '0') and (Scan_Dav_Sync(1) = '1') then bytes <= bytes (bytes'high-8 downto 0) & Data_in; end if; end if; -- works fine till here when '1' => if (shift = '1' and flag = '0' ) then first_letter <= bytes(bytes'high downto bytes'high-7); bytes <= bytes (bytes'high-8 downto 0) & first_letter; end if; when others =>--just ignore here bytes <= bytes (bytes'high-8 downto 0) & Data_in; end case; end process; O1 <= bytes(31 downto 24); O2 <= bytes(23 downto 16); O3 <= bytes(15 downto 8); O4 <= bytes(7 downto 0); end bhv;
