indu15
Junior Member level 3
I am implementing serial in serial out 72 bit shift register using VHDL. When the enable signal is high, I want the shift register to shift 72 times, irrespective of whether enable continues to be high or low. I have written the following code which is working only when the enable is high. Can anyone please let me know how to shift data once enable is high and then does not depend on enable to shift the data?
library ieee;
use ieee.std_logic_1164.all;
entity SR is
port(clk, din, rst, enable : in std_logic;
sr_out : inout std_logic_vector(71 downto 0));
end SR;
architecture behavioral of SR is
signal shift_reg: std_logic_vector(71 downto 0);
begin
process (clk, rst)
begin
if (rst = '0') then
shift_reg <= (others => '0');
elsif (clk'event and clk = '1') then
if enable= '1' then
shift_reg(70 downto 0) <= shift_reg(71 downto 1);
shift_reg(71) <= din;
end if;
end if;
end process;
sr_out <= shift_reg;
end behavioral;
Thanks a lot!
library ieee;
entity SR is
end SR;
begin
process (clk, rst)
begin
if (rst = '0') then
if enable= '1' then
end if;
end if;
end process;
end behavioral;
Thanks a lot!
