Register Log in
VHDL sequence detector
indu15
Member level 1
I have generated 0.5 Mhz clock from 50Mhz incoming clock by using synchronous counter clock enable and detecting the 00110001 pattern on the din input data and outputting (sync_detected) pulse once the last bit in the pattern is detected. When I implemented the code that is mentioned below I am able to generate the waveform in the image (I have zoomed in so that you can see the problem that I am facing). My problem is that sync_detected is generated at the falling edge of the clk_enable_0_5mhz but I want to have sync_detected at the rising edge of the clk_enable_0_5mhz i.e. at the same time as the last bit in the pattern is detected. Please check my code below and let me know where I am going wrong. I really appreciate your help. Thank you.
constant PATTERN_TO_DETECT : std_logic_vector(7 downto 0) := "00110001";
signal decoder_shift8 : std_logic_vector(7 downto 0);
signal temp1 : unsigned(6 downto 0);
begin
----Generating 0.5Mhz clock from 50Mhz global clock
pattern_detector_clk_0_5mhz : process(clk_50mhz)
        begin
	if clk_50mhz'event and clk_50mhz = '1' then
		if rst = '0' then
		clk_enable_0_5mhz <= '0';
		temp1 <= (others => '0');
	                     else
				temp1 <= temp1 +"1";
			if temp1 >= x"63" then		--hexadecimal value for 99
				clk_enable_0_5mhz <= not clk_enable_0_5mhz;
			end if;
		 end if;
	end if;
	end process;
	--00110001 pattern detecting by using shift register
decoder_shift_reg_proc: process (clk_50mhz)
      begin
         if rst = '0' then
            decoder_shift8 <= (others => '0');
         elsif clk_enable_0_5mhz = '1' then
                for i in 0 to 6 loop
                decoder_shift8(i+1) <= decoder_shift8(i);
            end loop;
            decoder_shift8(0) <= din;
        end if;
      end if;
      end process;
sync_detector_process: process(decoder_shift8)
	begin
	 if decoder_shift8 = PATTERN_TO_DETECT or decoder_shift8 = not PATTERN_TO_DETECT then
                sync_detected <= '1';
            else
                sync_detected <= '0';
          end if;
          end process;
 end;
barry
Advanced Member level 5
California, USA
Not sure what you want here. There is no signal named dout in your code. And not sure what you mean by "I want dout (output) to be at the same time as it detects the last bit in the pattern".
aruipksni
Full Member level 6
I have generated 0.5 Mhz clock from 50Mhz incoming clock by using synchronous counter clock enable and detecting the 00110001 pattern on the din input data and dout (output) I am getting is sync pulse as shown in image . but I want dout (output) to be at the same time as it detects the last bit in the pattern. Please check my code below and let me know where I am going wrong. I really appreciate your help. Thank you.
begin
if rst = '0' then
else
end if;
end if;
end if;
end process;
begin
if rst = '0' then
end loop;
end if;
end if;
end process;
begin
else
end if;
end process;
i think the code posted is irelevant to the question.
i think this is a job interview question when you need to get serial bit stream and detect a pattern , do something regarding the pateran and output bitstream
with revised pattern or in this case with a parallel sync detect signal.
but this is just what is i am guessing.
indu15
Member level 1
This is not a job interview question. It is a part of the code for the project I am working on. Sorry, I was not clear with my question. I have edited my question I hope this time it is clear. Please see my question again and help me to solve the problem. Thank you.
TrickyDicky
Basic answer - you cant. The edge detection will always lag at least 1 clock behind the edge of the signal as you have to register it to be able to see the edge.
You may want to register clk_enable_0_5mhz and align it with your edge detect.
indu15
Member level 1
Thanks TrickyDicky for the reply. Can you please let me know what do you mean by "You may want to register clk_enable_0_5mhz and align it with your edge detect"??
Can I align the sync_detect with the data in (din) signal???
TrickyDicky
exactly what I said - register it and output it
process(clk)
begin
  if rising_edge(clk) then
    clk_enable_0_5mhz_out <= clk_enable_0_5mhz;
  end if;
end process;
clk_enable_0_5mhz_out will be aligned with your sync_detect
Reactions: indu15
    indu15
aruipksni
Full Member level 6
i think you mean for something like this.
process (clk_50m)
begin
if rising_edge(clk50m) then
if (clk_en0,5m = '0') then
else
end if;
end if;
end pocess;
Toggle Sidebar
