manuel1139
Member level 1
sdram vhdl
Hi!
I am going to build an SDRAM controller and asking myself how far this can simplified until at least something can be "seen"?
Is it possible to run, say a 66 MHZ SDRAM, with less speed? (to avoid timing issues in the first time) Or is this the speed that the clock must have?
What wold be absolutely neccesssary to write 1 byte and read it back?
I think I have to do some configuration on the RAM first. Is it possible to read that config word back? Can I check somehow if the RAM is configured correctly ?
How would someone start out such an task? Wich tools do you think are neccessary?
Thanks & best regards
Manuel
Hi!
Manuel
