VHDL rules for arithmetic operations
shaiko
Advanced Member level 5
Hello,
1.When multiplying 2 unsigned vectors in VHDL, must they be at the same length?
2.Is it legal to multiply an unsigned vector with an integer? Or both operands must be of the same type?
I'm pretty sure for 1. the inputs to a multiply can be different lengths and the result will be the two lengths added together.
For 2. the numeric_std package for 97 shows unsigned-natural and signed-integer, which makes sense as integer can have negative values.
Reactions: shaiko
    shaiko
Thanks,
I verified #1 (modelim compilation + Quartus synthesis). Works as you said.
Regarding #2 - what about multiplying an unsigned vector with type natural (or positive)?
Reactions: shaiko and FvM
    FvM
    shaiko
numeric_std defines * for unsigned/signed * integer and integer * unisnged/signed.
natural and positive are subtypes of integer, so will work just fine.
You really need a good reference book - this is basic stuff.
https://www.doulos.com/content/products/golden_reference_guides.php
Tricky are you sure you aren't mistaken, I just looked at the package on the IEEE site and the 1076.2-1996 package doesn't define * for unsigned/signed.
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
-- Id: A.15
  function "*" (L, R: UNSIGNED) return UNSIGNED;
  -- Result subtype: UNSIGNED((L'LENGTH+R'LENGTH-1) downto 0)
  -- Result: Performs the multiplication operation on two UNSIGNED vectors
  --         that may possibly be of different lengths.
  -- Id: A.16
  function "*" (L, R: SIGNED) return SIGNED;
  -- Result subtype: SIGNED((L'LENGTH+R'LENGTH-1) downto 0)
  -- Result: Multiplies two SIGNED vectors that may possibly be of
  --         different lengths.
  -- Id: A.17
  function "*" (L: UNSIGNED; R: NATURAL) return UNSIGNED;
  -- Result subtype: UNSIGNED((L'LENGTH+L'LENGTH-1) downto 0)
  -- Result: Multiplies an UNSIGNED vector, L, with a nonnegative
  --         INTEGER, R. R is converted to an UNSIGNED vector of
  --         SIZE L'LENGTH before multiplication.
  -- Id: A.18
  function "*" (L: NATURAL; R: UNSIGNED) return UNSIGNED;
  -- Result subtype: UNSIGNED((R'LENGTH+R'LENGTH-1) downto 0)
  -- Result: Multiplies an UNSIGNED vector, R, with a nonnegative
  --         INTEGER, L. L is converted to an UNSIGNED vector of
  --         SIZE R'LENGTH before multiplication.
  -- Id: A.19
  function "*" (L: SIGNED; R: INTEGER) return SIGNED;
  -- Result subtype: SIGNED((L'LENGTH+L'LENGTH-1) downto 0)
  -- Result: Multiplies a SIGNED vector, L, with an INTEGER, R. R is
  --         converted to a SIGNED vector of SIZE L'LENGTH before
  --         multiplication.
  -- Id: A.20
  function "*" (L: INTEGER; R: SIGNED) return SIGNED;
  -- Result subtype: SIGNED((R'LENGTH+R'LENGTH-1) downto 0)
  -- Result: Multiplies a SIGNED vector, R, with an INTEGER, L. L is
  --         converted to a SIGNED vector of SIZE R'LENGTH before
  --         multiplication.
https://standards.ieee.org/downloads/1076/1076.2-1996/numeric_std.vhdl
It has been change to the following in the 1076-2008, which also doesn't define * for signed/unsigned. :???:
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
-- Id: A.15
  function "*" (L, R : UNRESOLVED_UNSIGNED) return UNRESOLVED_UNSIGNED;
  -- Result subtype: UNRESOLVED_UNSIGNED((L'LENGTH+R'LENGTH-1) downto 0)
  -- Result: Performs the multiplication operation on two UNRESOLVED_UNSIGNED vectors
  -- Id: A.16
  function "*" (L, R : UNRESOLVED_SIGNED) return UNRESOLVED_SIGNED;
  -- Result subtype: UNRESOLVED_SIGNED((L'LENGTH+R'LENGTH-1) downto 0)
  -- Result: Multiplies two UNRESOLVED_SIGNED vectors that may possibly be of
  -- Id: A.17
  function "*" (L : UNRESOLVED_UNSIGNED; R : NATURAL) return UNRESOLVED_UNSIGNED;
  -- Result subtype: UNRESOLVED_UNSIGNED((L'LENGTH+L'LENGTH-1) downto 0)
  -- Result: Multiplies an UNRESOLVED_UNSIGNED vector, L, with a nonnegative
  --         INTEGER, R. R is converted to an UNRESOLVED_UNSIGNED vector of
  -- Id: A.18
  function "*" (L : NATURAL; R : UNRESOLVED_UNSIGNED) return UNRESOLVED_UNSIGNED;
  -- Result subtype: UNRESOLVED_UNSIGNED((R'LENGTH+R'LENGTH-1) downto 0)
  -- Result: Multiplies an UNRESOLVED_UNSIGNED vector, R, with a nonnegative
  --         INTEGER, L. L is converted to an UNRESOLVED_UNSIGNED vector of
  -- Id: A.19
  function "*" (L : UNRESOLVED_SIGNED; R : INTEGER) return UNRESOLVED_SIGNED;
  -- Result subtype: UNRESOLVED_SIGNED((L'LENGTH+L'LENGTH-1) downto 0)
  -- Result: Multiplies an UNRESOLVED_SIGNED vector, L, with an INTEGER, R. R is
  --         converted to an UNRESOLVED_SIGNED vector of SIZE L'LENGTH before
  --         multiplication.
  -- Id: A.20
  function "*" (L : INTEGER; R : UNRESOLVED_SIGNED) return UNRESOLVED_SIGNED;
  -- Result subtype: UNRESOLVED_SIGNED((R'LENGTH+R'LENGTH-1) downto 0)
  -- Result: Multiplies an UNRESOLVED_SIGNED vector, R, with an INTEGER, L. L is
  --         converted to an UNRESOLVED_SIGNED vector of SIZE R'LENGTH before
  --         multiplication.
Reactions: shaiko
    shaiko
In contrast to legacy std_logic_arith, ieee.numeric_std has no automatic type conversion from unsigned to signed, thus unsigned*signed or unsigned*negative_integer isn't supported.
But I don't hear that Tricky is suggesting anything different.
Reactions: shaiko
    shaiko
Ok - I stand a little corrcted. You can never multipliy an unsigned and signed as it wouldnt make sense.
Neither would multiplying unsigned with an integer (as it can have negative values).
Ok multiplicates:
us * us
s *s
s * integer (and other way around - this covers positives and naturals)
us * natural (and other way around - this also covers positives).
The 2008 definition uses unresolved_signed by default as this was how std_logic was changed - std_logic_vector became a subtype of std_ulogic_vector, rather than an array of std_logic. So they did the same change in numeric_std.
As unsigned/signed are just subtypes of unresolved_(un)signed, you can use the functions you quoted.
Reactions: shaiko
    shaiko
The length of us * us will be the sum of both - simple enough.
But what about:
us * natural (in case the natural is unconstrained)
Will the tool simply assume that the natural number is 32 bits long ?
Or will it treat it as a constrained unsigned exactly the length of its binary equivalent?
Reactions: shaiko
    shaiko
ads-ee,
post #6 is VERY helpful.
I couldn't find this package on IEEE site.
I found it on another site, but I'd like to have the original reference.
Can you please post the link ?
I stumbled upon this definition of the "+" function:
  -- Id: A.3
  function "+" (L, R: UNSIGNED) return UNSIGNED;
  -- Result subtype: UNSIGNED(MAX(L'LENGTH, R'LENGTH)-1 downto 0).
  -- Result: Adds two UNSIGNED vectors that may be of different lengths.
Can't find the scene behind it.
I'd expect the function to take into consideration the possibility of an overflaw and the result to be defined as one bit longer than the longest of operands - yet I see the length of the result is simply defined as the length of the longest operand without any extra bits.
Am I missing something?
ads-ee,
  -- Id: A.3
Nope. No overflow is done
If you want overflow you need to extend the inputs by a bit - which is common:
op <= ('0' & a) + ('0' & b);
Reactions: shaiko
    shaiko
If you want overflow taken into consideration, then you should consider using the fixed point package instead.
Kevin Jennings
Reactions: shaiko
    shaiko
It's sufficient to extend one of both operands to avoid result truncation. And you can use numeric_std resize(), which also performs the necessary sign extension of signed numbers.
op <= resize(a, op'length) + b;
Reactions: shaiko
    shaiko
