library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
-- entity definition
entity pulse_5clk is
port(
clk, reset: in std_logic;
go, stop: in std_logic;
pulse: out std_logic
end pulse_5clk;
-- architecture definition
architecture fsmd_arch of pulse_5clk is
constant P_WIDTH: natural := 5;
type fsmd_state_type is (idle, delay);
signal state_reg, state_next: fsmd_state_type;
signal c_reg, c_next: unsigned(3 downto 0);
begin
-- state and data registers
process(clk, reset)
begin
if (reset = '1') then
state_reg <= idle;
c_reg <= (others => '0');
elsif (clk'event and clk='1') then
state_reg <= state_next;
c_reg <= c_next;
end if;
end process;
-- next state logic & data path functional units/routing
process(state_reg,go,stop,c_reg)
begin
pulse <= '0';
c_next <= c_reg;
case state_reg is
when idle =>
if go='1' then
state_next <= delay;
else
state_next <= idle;
end if;
c_next <= (others => '0');
when delay =>
if stop='1' then
state_next <= idle;
else
if (c_reg = P_WIDTH - 1) then
state_next <= idle;
else
c_next <= c_reg + 1;
end if;
end if;
pulse <= '1';
end case;
end process;
end fsmd_arch;
