VHDL package, for loop, constant array.
HDE
Newbie level 2
Hi everyone,
I have a question in regard to a vhdl package I have created. Hereafter, is the code that works fine:
library IEEE;
use IEEE.STD_LOGIC_1164.all;
USE ieee.math_real.log2;
USE ieee.math_real.ceil;
package PKG_globalConstants is
constant Width : integer := 7;
constant FaultyChannels : integer := 3;
constant clockPeriod : INTEGER := 20;
constant pwmPeriod : INTEGER := 320000;
constant dcIintegral : positive := 22;
constant cntWidth : INTEGER := INTEGER(CEIL(LOG2(REAL(pwmPeriod/clockPeriod))))
type pulseShift_array is array (0 to FaultyChannels) of positive;
constant pulseShift : pulseShift_array := ( (2**cntWidth)/(Width-3), (2**cntWidth)/(Width-2), (2**cntWidth)/(Width-1), (2**cntWidth)/(Width) ); ---(line that I need to replace)
end PKG_globalConstants;
My question is, is it possible to use the following part of code in order to make pulseShift constant array parametric?
I use Xilinx WEB ise 13.2 and I get a syntax error for the 'loop' example. If what I need to do is possible in VHDL, could you please give me the answer? Thanks in advance.
Hearafter is the code I would like to insert in my package;
constant pulseShift : pulseShift_array;
forLoop: for i in 0 to FaultyChannels generate
pulseShift(i) := (2**cntWidth)/(Width-(FaultyChannels-i));
end generate;
yes, you can use a for loop. But a for loop is a procedural bit of VHDL, so needs to be inside a process, function or procedure. (a generate loop must be inside an architecture, and cant be used for constants).
Luckily, you can call a function to initialise a constant:
function pulseShift_init return pulseShift_array is
  variable temp : pulseShift_array;
begin
  forLoop: for i in 0 to FaultyChannels loop
    temp(i) := (2**cntWidth)/(Width-(FaultyChannels-i));
  end loop;
  return temp;
end function pulseShift_init;
constant pulseShift : pulseShift_array := pulseShift_init;
---------- Post added at 18:47 ---------- Previous post was at 18:42 ----------
another quick thing I just remembered, you cannot put more than a function declaration inside a package, the body of the function has to be inside the package body.
ie:
  function pulseShift_init return pulseShift_array;
end package PKG_globalConstants;
package body PKG_globalConstants is
  begin
    end loop;
    return temp;
end package body PKG_globalConstants;
Reactions: HDE
    HDE
Constants can be generated in a loop by using an optional "block_declarative_item" and a begin keyword. There are however easier ways to achieve the same, particularly initialization functions, as you explained.
Reactions: HDE
    HDE
Thank you for all the valuable information!
TrickiDicky your example worked fine!
