ustinoff
Member level 2
Hello.
The code:
I cannt understand why o_data is always in 'X' condition, reg is always 'zero', but check_in and buff_count works correctly. I read some sources about VHDL, but i didn't find (or didn't understand) how to fix it
The code:
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity test is port ( i_arst : in std_logic; i_clk : in std_logic; i_data : in std_logic_vector (3 downto 0); o_data : out std_logic_vector (3 downto 0) ); end entity; architecture arch of test is type fsm_state is (S0,S1); signal fsm_cnt : fsm_state; signal buff_count : unsigned (3 downto 0); signal check_in : std_logic; signal s0_count : unsigned (3 downto 0); signal reg : unsigned(3 downto 0); type buff_type is array (3 downto 0) of unsigned (3 downto 0); signal buff : buff_type; begin fsm_proc : process(i_arst, i_clk) begin if i_arst = '1' then s0_count <= (others=>'0'); check_in <= '1'; fsm_cnt <= S0; reg <= (others=>'0'); buff_count <= (others=>'0'); buff <= (others=>(others=>'0')); elsif rising_edge(i_clk) then if (check_in = '1' and to_integer(unsigned(i_data)) >= 8) then check_in <= '0'; s0_count <= (others=>'0'); fsm_cnt <= S0; elsif check_in = '0' then case fsm_cnt is when S0 => if s0_count = 15 then fsm_cnt <= S1; else s0_count <= s0_count + 1; end if; when S1 => buff(0) <= unsigned(i_data); buff(3 downto 1) <= buff(2 downto 0); if buff_count = 3 then buff_count <= (others =>'0'); check_in <= '1'; reg <= buff(3); else buff_count <= buff_count + 1; end if; when others => o_data <= (others=>'0'); end case; end if; end if; end process; o_data <= std_logic_vector(reg); end arch;
