VHDL convert string to integer
shedo
Junior Member level 1
Hi all,
I want to convert a strings into integer values.
eg: "123" => 123
Can someone recommend a "best" way of converting strings to integers in VHDL?
Thanks
how about this?
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
  --Will take a string in the given radix and conver it to an integer
  function string_to_int(x_str : string; radix : positive range 2 to 36 := 10) return integer is
    constant STR_LEN          : integer := x_str'length;
    variable chr_val          : integer;
    variable ret_int          : integer := 0;
    variable do_mult          : boolean := true;
    variable power            : integer := 0;
  begin
    for i in STR_LEN downto 1 loop
      case x_str(i) is
        when '0'       =>   chr_val := 0;
        when '1'       =>   chr_val := 1;
        when '2'       =>   chr_val := 2;
        when '3'       =>   chr_val := 3;
        when '4'       =>   chr_val := 4;
        when '5'       =>   chr_val := 5;
        when '6'       =>   chr_val := 6;
        when '7'       =>   chr_val := 7;
        when '8'       =>   chr_val := 8;
        when '9'       =>   chr_val := 9;
        when 'A' | 'a' =>   chr_val := 10;
        when 'B' | 'b' =>   chr_val := 11;
        when 'C' | 'c' =>   chr_val := 12;
        when 'D' | 'd' =>   chr_val := 13;
        when 'E' | 'e' =>   chr_val := 14;
        when 'F' | 'f' =>   chr_val := 15;
        when 'G' | 'g' =>   chr_val := 16;
        when 'H' | 'h' =>   chr_val := 17;
        when 'I' | 'i' =>   chr_val := 18;
        when 'J' | 'j' =>   chr_val := 19;
        when 'K' | 'k' =>   chr_val := 20;
        when 'L' | 'l' =>   chr_val := 21;
        when 'M' | 'm' =>   chr_val := 22;
        when 'N' | 'n' =>   chr_val := 23;
        when 'O' | 'o' =>   chr_val := 24;
        when 'P' | 'p' =>   chr_val := 25;
        when 'Q' | 'q' =>   chr_val := 26;
        when 'R' | 'r' =>   chr_val := 27;
        when 'S' | 's' =>   chr_val := 28;
        when 'T' | 't' =>   chr_val := 29;
        when 'U' | 'u' =>   chr_val := 30;
        when 'V' | 'v' =>   chr_val := 31;
        when 'W' | 'w' =>   chr_val := 32;
        when 'X' | 'x' =>   chr_val := 33;
        when 'Y' | 'y' =>   chr_val := 34;
        when 'Z' | 'z' =>   chr_val := 35;
        when '-' =>
          if i /= 1 then
            report "Minus sign must be at the front of the string" severity failure;
          else
            ret_int           := 0 - ret_int;
            chr_val           := 0;
            do_mult           := false;    --Minus sign - do not do any number manipulation
          end if;
        when others => report "Illegal character for conversion for string to integer" severity failure;
      end case;
      if chr_val >= radix then report "Illagel character at this radix" severity failure; end if;
      if do_mult then
        ret_int               := ret_int + (chr_val * (radix**power));
      end if;
      power                   := power + 1;
    end loop;
    return ret_int;
  end function;
Reactions: shedo
    shedo
    V
how about this?
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
  begin
      case x_str(i) is
        when '-' =>
          if i /= 1 then
          else
            chr_val           := 0;
          end if;
      end case;
      if do_mult then
      end if;
      power                   := power + 1;
    end loop;
    return ret_int;
  end function;
Thanks a lot!!!!!
Dont try and synthesise it though. Its only for testbenches.
mmm, ok...
I have this problem: I receive a string from uart and I need to convert it to integer to make an operation. My problem is the conversion from string to int.
Can you help?
well thats different
Why is it sending a string? why cant it just send the actual integer value?
You dont actually have a string type coming out of the uart, what you have is a load of data.
I send a single character at a time and fpga receives the corrisponding ascii code. When I send a special character ('!' choose by me) the fpga compact the previous characters into a string.
You're thinking in SW terms. Nope the FPGA doesn't compact the characters into a string it just has a bunch of ASCII codes stored in a memory buffer of some kind (probably a FIFO).
So take a look at an ASCII table and the HEX values you see is what is sitting around in the buffer. What you do with those values is up to you.
Here is some sample, untested code. Assuming that I don't have a syntax error or something, it will synthesize just fine.
-- Assumed inputs are:
Data_Recieved_From_Uart = std_ulogic that is active on the clock cycle when there is valid input from the UART
Uart_Data = std_logic_vector(7 downto 0) which is the byte of ASCII data received from the UART
signal Int_Accumulate natural range 0 to 9999; -- Assumes you will only have four digits.  If not, then change the upper end of the range
signal Int_Out natural range 0 to 9999; -- Ditto
process(Clock)
begin
   if rising_edge(Clock) then
      Output_Valid <= '0';  -- Default unless overridden below
      if (Data_Recieved_From_Uart = '1') then
         if (Uart_Data = Start_Character) then -- You need to decide on a start character
            Int_Accumulate <= 0;
            -- You might be OK with using the ! not only as an 'end' character but to
            -- also initialize for the next go round.  If that's the case, then delete
            -- the following statement and combine this branch with the next branch.
            -- All the next statement is doing is giving you an initial value prior
            -- to the very first number that comes in.
            Int_Out <= 0;
         elsif (Uart_Data = End_Character) then -- i.e. the "!" that you mentioned
            Output_Valid <= '1';
            Int_Out <= Int_Accumulate;
            Int_Accumulate <= 0;  -- This statement would be important if "!" does double duty as both start and end character
         else
            -- The following assumes the Uart data is valid...i.e. 0-9.  If you want to
            -- add checking so that you're not adding up invalid characters like the
            -- alphabet, then add a check here
            Int_Accumulate <= 10 * Int_Accumulate + unsigned(Uart_Data(3 downto 0);
         end if;
      end if;
   end if;
end process;
Kevin Jennings
Thank you very much!
