Jan 5, 2007 #1 A adamsogood Member level 1 Joined Jun 15, 2006 Messages 33 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,538 Hi, There are two VHDL coding styles to check the event of clock rising edge: 1. if (clk='1' and clk'event) 2. if (risingedge(clk)) Please suggest me which one is better? and why? Thanks a lot.
Jan 5, 2007 #2 gliss Advanced Member level 2 Joined Apr 22, 2005 Messages 691 Helped 75 Reputation 150 Reaction score 16 Trophy points 1,298 Activity points 5,892 rising edge vhdl #1 is more common and I believe has been in the VHDL spec longer. #2 is valid VHDL but looks more like Verilog. I would go with #1.
Jan 5, 2007 #3 A agent_009 Member level 2 Joined Dec 17, 2006 Messages 47 Helped 10 Reputation 20 Reaction score 3 Trophy points 1,288 Activity points 1,563 vhdl risingedge both are Ok, #2 is defined in the ieee library, #1 is default vhdl
Jan 6, 2007 #4 rakesh_aadhimoolam Full Member level 4 Joined Mar 14, 2006 Messages 206 Helped 19 Reputation 38 Reaction score 2 Trophy points 1,298 Activity points 2,751 rising edge syntax vhdl Yes..........there is no problem of using both the constructs............. good luck
Jan 6, 2007 #5 V vinod_g Member level 4 Joined Nov 29, 2006 Messages 71 Helped 8 Reputation 16 Reaction score 2 Trophy points 1,288 Activity points 1,681 vhdl + rising edge 1: In this the statement below will execute when there is event on the clk and the clock =1 means the clock previous value may be O,Z,X among these values 2:but in this it will only from 0 to 1 transition not from Z,X So, according to the need u can use, If any changes , inform ............... Thanks ok
Jan 30, 2007 #6 dragonight_x Member level 4 Joined Mar 25, 2006 Messages 71 Helped 2 Reputation 4 Reaction score 0 Trophy points 1,286 Location Egypt - Cairo Activity points 1,667 vhdl risingedge Both coding styles are correct ...............you can use either one
