jianhuachews
Member level 2
Hi guys i've had all my codes done but when i download the program to my board, the four 7-segment shows the same number (lets say i press 3). It wasn't what i intended. i want it to be like when i press a 123 it first shows 1 in the first segment, then 1 in the second segment while 2 in the first segment, and finally 1 in the third segment while 2 in the second segment while 3 in the first segment (shifting).
Can anyone look at my codes and guide me along? of cus i have my top lvl and crystal code all done but i think it's this 3 program that affects the unexpected behavior instead..
thanks in adv!
keypad decoder
7segment
mux
thanks in adv!
keypad decoder
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.STD_LOGIC_UNSIGNED.all;
entity key_decode is
port (
key_out : out std_logic_vector(15 downto 0);
enable1 : out std_logic;
row_indata, column_in : in std_logic_vector(3 downto 0);
clk1, rst1 : in std_logic
end key_decode;
architecture Behavioral of key_decode is
signal key_data: std_logic_vector(3 downto 0);
signal key_out_s: std_logic_vector(15 downto 0);
signal key_detect: std_logic;
begin
enable1 <= '0' when row_indata = "1111" else
'1';
process(clk1)
begin
if (rst1 = '1') then
key_out_s <= (others => '0');
key_detect <= '0';
elsif(clk1'event and clk1 ='1') then
if (key_detect = '1') then
key_out_s(15 downto 4) <= key_out_s(11 downto 0);
key_out_s(3 downto 0) <= key_data;
key_detect <= '0';
end if;
if(row_indata="0111" and column_in="0111") then
key_data<="0001"; -- binary for 1
key_detect <= '1';
elsif(row_indata="0111" and column_in="1011") then
key_data<="0010"; -- binary for 2
key_detect <= '1';
elsif(row_indata="0111" and column_in="1101") then
key_data<="0011"; -- binary for 3
key_detect <= '1';
elsif(row_indata="0111" and column_in="1110") then
key_data<="1111"; -- binary for F
key_detect <= '1';
elsif(row_indata="1011" and column_in="0111") then
key_data<="0100"; -- binary for 4
key_detect <= '1';
elsif(row_indata="1011" and column_in="1011") then
key_data<="0101"; -- binary for 5
key_detect <= '1';
elsif(row_indata="1011" and column_in="1101") then
key_data<="0110"; -- binary for 6
key_detect <= '1';
elsif(row_indata="1011" and column_in="1110") then
key_data<="1110"; -- binary for E
key_detect <= '1';
elsif(row_indata="1101" and column_in="0111") then
key_data<="0111"; -- binary for 7
key_detect <= '1';
elsif(row_indata="1101" and column_in="1011") then
key_data<="1000"; -- binary for 8
key_detect <= '1';
elsif(row_indata="1101" and column_in="1101") then
key_data<="1001"; -- binary for 9
key_detect <= '1';
elsif(row_indata="1101" and column_in="1110") then
key_data<="1101"; -- binary for D
key_detect <= '1';
elsif(row_indata="1110" and column_in="0111") then
key_data<="1010"; -- binary for A
key_detect <= '1';
elsif(row_indata="1110" and column_in="1011") then
key_data<="0000"; -- binary for 0
key_detect <= '1';
elsif(row_indata="1110" and column_in="1101") then
key_data<="1011"; -- binary for B
key_detect <= '1';
elsif(row_indata="1110" and column_in="1110") then
key_data<="1100"; -- binary for C
key_detect <= '1';
end if;
end if;
end process;
key_out <= key_out_s;
end Behavioral;
7segment
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
entity segment7 is
port (
seg_out : out std_logic_vector(6 downto 0);
mux_in : in std_logic_vector(3 downto 0)
end segment7;
architecture Behavioral of segment7 is
begin
seg_out <= "1000000" when mux_in="0000" else
"1111001" when mux_in="0001" else
"0100100" when mux_in="0010" else
"0110000" when mux_in="0011" else
"0011001" when mux_in="0100" else
"0010010" when mux_in="0101" else
"0000010" when mux_in="0110" else
"1111000" when mux_in="0111" else
"0000000" when mux_in="1000" else
"0011000" when mux_in="1001" else
"0001000" when mux_in="1010" else
"0000011" when mux_in="1011" else
"1000110" when mux_in="1100" else
"0100001" when mux_in="1101" else
"0000110" when mux_in="1110" else
"0001110";
end Behavioral;
mux
library IEEE;
entity mux is
port (
mux_out : out std_logic_vector(3 downto 0);
key_in : in std_logic_vector(15 downto 0);
mux_g : in std_logic_vector(3 downto 0);
clk,rst2 : in std_logic
end mux;
architecture Behavioral of mux is
signal firstseg: std_logic_vector(3 downto 0);
signal secondseg: std_logic_vector(3 downto 0);
signal thirdseg: std_logic_vector(3 downto 0);
signal fourthseg: std_logic_vector(3 downto 0);
begin
firstseg <= key_in(3 downto 0); --G1<=mux_g(0), first
secondseg <= key_in(7 downto 4);
thirdseg <= key_in(11 downto 8);
fourthseg <= key_in(15 downto 12);
process(clk)
begin
if (rst2 = '1') then
mux_out <= (others => '0');
elsif(clk'event and clk='1') then
if(mux_g="1110") then
mux_out<=firstseg;
elsif(mux_g="1101") then
mux_out<=secondseg;
elsif(mux_g="1011") then
mux_out<=thirdseg;
elsif(mux_g="0111") then
mux_out<=fourthseg;
end if;
end if;
end process;
end Behavioral;
