Very strange problems about bandgap
xiexi
Member level 4
The first tapeout ICs hrpoly resistor's unit value is 1.7k/um, the bandgap value is about 1.20V to 1.23V; and the second tapeout I only changes the metal 2 and metal1 mask, the bandgap block doesn't make any changes, but unluckily the process changes mainly that hrpoly resistor's unit value changes to 2k/um, so all the resistors' value used in bandgap block increase. When the second tapeout ICs comes back, the bandgap's value changes to about 1.23V to 1.26V.
I really can't understand why the result is so because the R1/R2 ratio can cancel the resistor's unit variation.(The simulation also shows that). Of course, the bandgap PTAT changes smaller, but does it cause the problems? Or any other reason? Thank you for your instruction.
DenisMark
Full Member level 6
Russia
For untrimmed bandgap 5% vref variation due process variation is normal. R1/R2 is not a reason for variation of "bandgap's value about 1.23V to 1.26V" for ur case. U must keep in mind that parameters of diodes changes too, that is real reason.
elbadry
Full Member level 6
Egypt
I think also that contact resistance value and tempco will have its effect on the bandgap voltage. Mismatches can also be change the bg value
pfd001
Advanced Member level 1
It should be the diode parameters variations
andy2000a
Advanced Member level 2
to sum up . bandgap use parastic Pnp device
and consider Resistor variation , no trim bandgap will drfit some voltage ..
another problem is "density or concentration" I ever met , from WAT restsor data is Ok , but really bandgap design use 2 long channel resistor . and cause resistor value mismatch . WAT only measure little square resistor
but in general , we use "many square" for bandgap resistor circuit .
laglead
Full Member level 5
I think there are two reasons:
1. Parasitic PNP characteristc change.
2. PTAT current change due to resistor value change. This will lead to little change in Vbe.
bageduke
This brought me another question about BGR. It's said that the size of diode to form Vbe in Vbgr can be arbitary. But with same current, different size of diode will generate different Vbe, and this adds up with PTAT current across resistor, the final Vbgr will be generated slightly different. Is this correct? Or I missed some points.
Thanks,
laglead
Full Member level 5
Thanks,
Hi, Bageduke,
When diode area is different, their current density will also change (same current). This may change the Vbe(T) curve a little and will lead to different R1/R2 ratio. This effect togather with Vbe wmay change the final Vbg.
bageduke
Thanks, laglead
So final Vbgr does relate to the area of diode? Then why doesn't this relationship reflect in the equations we derived for bandgap reference? I mean dVbe/dT+d(nVt)/dT=0.
And as I remember, dVbe/dT is independent of diode area, true or not?
Thanks,
laglead
Full Member level 5
hi, bageduke,
The final d(Vbe)/d(T)@T0=(Vbe-Vgo)/T0+(α-γ)(k/q).
Current density Jc≈T*exp(α). This α will affect Vbe value and then final Vbg value.
Regards
