Does anyone has an example of transmission gate (or MOS switch) verilogA code? Please provide an example you have. I already tried this but does not work.
module simple_switch(in, out, tp);
input in, tp;
output out;
electricl in, out, tp;
parameter real vth =0.4;
real vout
analog begin
if (V(tp) >= vth) begin
vout = V(in);
end else vout = 0;
V(out) <+ vout;
end
endmodule
tanh() has the very nice attribute that it is limited,
smooth and cannot blow up. It can be used to
approximate exponential behaviors in its transition
region without making a numerical mess.
Your switch really should contain finite "on" and
"off" conductances, so as to not cause said blowup
behaviors at reasonable current ("off") or voltage
("on") forcing. You have to bear in mind that the
final SPICE solution is not the only place you'll step.
In the middle of your Newton-Raphson trek you
would very much like there not to be land mines
and tiger pits. It's a long way to the beach.
Similarly it might be best if the tp transfer function
was not hyper-abrupt. Otherwise you might have the
unfortunate result of toggling your way to "timestep
too small" every time you flip the switch. The smooth
leisurely tanh(), used to convert tp position to a
conductance (range from slightly more than zero
to slightly less than infinity) and exporting a current
rather than asserting / de-asserting that two nodes
are suddenly and exactly equal, would be much easier
on the solver.
There is a site out there with a large amount of veriloga
"stuff" to rip off. It may be designersguide.org, but I
am not sure I'm remembering correctly.
