verilog .. warning problem.
smileysam
Member level 4
Iam getting the following warning in simulation:
# ** Warning: (vsim-3015) F:/verilog/up_down.vl(7): [PCDPC] - Port size (1 or 1) does not match connection size (3) for port 'count'.
Code is as Follows:
//up_down counter
module main_module(data,up_down,load,reset,enable,clock,count);
input[2] data;
input up_down,load,reset,enable;
inout clock;
output[2] count;
clock_gen i2(clock);
up_down i1 (data,up_down,load,reset,enable,clock,count);
endmodule
module up_down(data,up_down,load,reset,enable,clock,count);
input[2] data;
input up_down,load,reset,enable,clock;
output[2] count;
reg count;
always @(posedge clock or reset)
begin
if(reset) count <=3'b000;
else
if(enable)
begin
if(load) count<=data;
else
begin
if(up_down) count<= count+1;
else count<= count -1;
end
end
end
endmodule
module clock_gen(clock);
output clock;
reg clock;
initial
begin
clock =1;
forever
begin
#50 clock = 0;
#50 clock = 1;
end
end
endmodule
Added after 1 hours 7 minutes:
prob solved..
reg count; --> reg[2:0] count;
