Verilog synthesis question
eexuke
Full Member level 4
Full Member level 4
Dear all,
Assume I have two descriptions:
1) assign a = (b==3'd5 && c==3'd6)? 1'b1:1'b0;
2) assign a = (b==3'd5 && c==3'd6);
If I am using DC to do synthesis,which expression will have a smaller gate count?
Many thanks in advance!
actually the first one requires one extra mux to pass 1 or 0 to a.
i feel, but DC optimizes that mux because a = comparator output directly.
So,you suggest use the 2) expression?
Thanks!
I don't think it matters which you use as they should both synthesize to equivilant logic..
jelydonut
eexuke said:
Dear all,
I just wonder that why dont you try to synthesize this code
module test(
            a,
            b,
            c
input   [2:0]   b;
input   [2:0]   c;
output  a;
// assign a = (b==3'd5 && c==3'd6)? 1'b1:1'b0;
endmodule
and then check the result yourself :D
If you do that, you will find that DC will give the same result (with same constraint) in both of these cases. ( different library & condition will give different logic, but the result between 1 & 2 always the same)
Hope this help :D
[/img]
The newer the version than the 2001.03, The result is the same.
But you'd better write it with the always statement.
Because the synospsys have defects to treat the assign statement
Hi friends
but in 2004 and 2005 release i cant find assign state came in netlist.
i also tried RC (cadence).
no assign.
regards
aravind
In Leonardo-Spectrum
Cell: test View: INTERFACE Library: work
Total accumulated area :
Number of Function Generators : 2
Number of IBUF : 6
Number of OBUF : 1
Number of gates : 2
Number of accumulated instances : 9
Number of ports : 7
Number of nets : 15
Number of instances : 9
Cell Library References Total Area
IBUF xis3 6 x 1 6 IBUF
LUT3 xis3 1 x 1 1 Function Generators
LUT4 xis3 1 x 1 1 Function Generators
OBUF xis3 1 x 1 1 OBUF
Number of global buffers used: 0
Device Utilization for 3S50tq144
Resource Used Avail Utilization
IOs 7 97 7.22%
Global Buffers 0 8 0.00%
Function Generators 2 1536 0.13%
CLB Slices 1 768 0.13%
Dffs or Latches 0 1827 0.00%
Block RAMs 0 4 0.00%
Block Multipliers 0 4 0.00%
Block Multiplier Dffs 0 144 0.00%
Using default wire table: STD
Slack Table at End Points
End points Slack Arrival Required
rise fall rise fall
a/ : n/a 8.54 8.54 n/a n/a
Critical Path Report
Critical path #1, (unconstrained path)
NAME GATE ARRIVAL LOAD
c(2)/ 0.00 0.00 up 1.30
c_ibuf(2)/O IBUF 1.35 1.35 up 1.30
nx38/O LUT4 0.85 2.20 up 1.30
a_dup0/O LUT3 0.85 3.04 up 1.30
a_obuf/O OBUF 5.50 8.54 up 1.30
a/ 0.00 8.54 up 0.00
data arrival time 8.54
data required time not specified
unconstrained path
Critical path #2, (unconstrained path)
b(0)/ 0.00 0.00 up 1.30
b_ibuf(0)/O IBUF 1.35 1.35 up 1.30
unconstrained path
Critical path #3, (unconstrained path)
b(1)/ 0.00 0.00 up 1.30
b_ibuf(1)/O IBUF 1.35 1.35 up 1.30
unconstrained path
Critical path #4, (unconstrained path)
b(2)/ 0.00 0.00 up 1.30
b_ibuf(2)/O IBUF 1.35 1.35 up 1.30
unconstrained path
Critical path #5, (unconstrained path)
c(0)/ 0.00 0.00 up 1.30
c_ibuf(0)/O IBUF 1.35 1.35 up 1.30
a_dup0/O LUT3 0.85 2.20 up 1.30
a_obuf/O OBUF 5.50 7.69 up 1.30
a/ 0.00 7.69 up 0.00
data arrival time 7.69
unconstrained path
Critical path #6, (unconstrained path)
c(1)/ 0.00 0.00 up 1.30
c_ibuf(1)/O IBUF 1.35 1.35 up 1.30
unconstrained path
Number of IBUF : 6
Number of OBUF : 1
Number of gates : 2
Number of ports : 7
Number of nets : 15
IOs 7 97 7.22%
rise fall rise fall
nx44/O LUT4 0.85 2.20 up 1.30
unconstrained path
unconstrained path
unconstrained path
unconstrained path
unconstrained path
unconstrained path
Thanks!
both results same netlist with DC.
