kobay000
Newbie level 1
Hi guys, i am new at Verilog. I generated a working Verilog file using Matlab HDL Generation Tool. I tested it with 16 binary bits using assign parameters and it worked for this values. But i need an input [1x1000000] random binary matrix. The following code must use this matrix with 16 bits block. How can produce a random [1x1000000] binary matrix and use this matrix dividing it 16 bits blocks (at total 1000000/16=62500 blocks) ? I searched at the internet and found a parameter named "initial" and some says i need a testbench file. Also I must show bit changes on quartus ii with waveform. Here is my code. Thanks in advance.
`timescale 1 ns / 1 ns
module serpistirici
clk,
reset,
clk_enable,
veri_0,
veri_1,
veri_2,
veri_3,
veri_4,
veri_5,
veri_6,
veri_7,
veri_8,
veri_9,
veri_10,
veri_11,
veri_12,
veri_13,
veri_14,
veri_15,
ce_out,
serpistirilmis_veri_0,
serpistirilmis_veri_1,
serpistirilmis_veri_2,
serpistirilmis_veri_3,
serpistirilmis_veri_4,
serpistirilmis_veri_5,
serpistirilmis_veri_6,
serpistirilmis_veri_7,
serpistirilmis_veri_8,
serpistirilmis_veri_9,
serpistirilmis_veri_10,
serpistirilmis_veri_11,
serpistirilmis_veri_12,
serpistirilmis_veri_13,
serpistirilmis_veri_14,
serpistirilmis_veri_15
input clk;
input reset;
input clk_enable;
input signed [15:0] veri_0; // int16
input signed [15:0] veri_1; // int16
input signed [15:0] veri_2; // int16
input signed [15:0] veri_3; // int16
input signed [15:0] veri_4; // int16
input signed [15:0] veri_5; // int16
input signed [15:0] veri_6; // int16
input signed [15:0] veri_7; // int16
input signed [15:0] veri_8; // int16
input signed [15:0] veri_9; // int16
input signed [15:0] veri_10; // int16
input signed [15:0] veri_11; // int16
input signed [15:0] veri_12; // int16
input signed [15:0] veri_13; // int16
input signed [15:0] veri_14; // int16
input signed [15:0] veri_15; // int16
output ce_out;
output signed [15:0] serpistirilmis_veri_0; // int16
output signed [15:0] serpistirilmis_veri_1; // int16
output signed [15:0] serpistirilmis_veri_2; // int16
output signed [15:0] serpistirilmis_veri_3; // int16
output signed [15:0] serpistirilmis_veri_4; // int16
output signed [15:0] serpistirilmis_veri_5; // int16
output signed [15:0] serpistirilmis_veri_6; // int16
output signed [15:0] serpistirilmis_veri_7; // int16
output signed [15:0] serpistirilmis_veri_8; // int16
output signed [15:0] serpistirilmis_veri_9; // int16
output signed [15:0] serpistirilmis_veri_10; // int16
output signed [15:0] serpistirilmis_veri_11; // int16
output signed [15:0] serpistirilmis_veri_12; // int16
output signed [15:0] serpistirilmis_veri_13; // int16
output signed [15:0] serpistirilmis_veri_14; // int16
output signed [15:0] serpistirilmis_veri_15; // int16
wire enb;
wire signed [15:0] veri [0:15]; // int16 [16]
reg signed [15:0] serpistirilmis_veri [0:15]; // int16 [16]
reg signed [15:0] serpistirici_A_1 [0:15]; // int16 [16]
reg signed [31:0] serpistirici_k_1; // int32
reg signed [31:0] serpistirici_t_0_1; // int32
reg signed [31:0] serpistirici_t_1_1; // int32
reg signed [31:0] serpistirici_t_2_1; // int32
reg signed [31:0] serpistirici_t_3_1; // int32
reg signed [63:0] serpistirici_cast_1 [0:3]; // sfix64 [4]
reg signed [63:0] serpistirici_add_cast_2 [0:3]; // sfix64 [4]
reg signed [63:0] serpistirici_add_cast_0_1 [0:3]; // sfix64 [4]
reg signed [63:0] serpistirici_add_cast_1_1 [0:3]; // sfix64 [4]
assign veri[0] = veri_0;
assign veri[1] = veri_1;
assign veri[2] = veri_2;
assign veri[3] = veri_3;
assign veri[4] = veri_4;
assign veri[5] = veri_5;
assign veri[6] = veri_6;
assign veri[7] = veri_7;
assign veri[8] = veri_8;
assign veri[9] = veri_9;
assign veri[10] = veri_10;
assign veri[11] = veri_11;
assign veri[12] = veri_12;
assign veri[13] = veri_13;
assign veri[14] = veri_14;
assign veri[15] = veri_15;
assign enb = clk_enable;
always @* begin
//spssa
//Oluþturulacak ara matrisin satýr sayýsý
//Gönderilecek verinin 4 ün katý olup olmadýðýný kontrol etme, eðer deðilse
//eksik bit sayýsý kadar boþluðu temsil eden sýfýr deðerini girme
//Ara matrisi oluþturma
for(serpistirici_k_1 = 0; serpistirici_k_1 <= 15; serpistirici_k_1 = serpistirici_k_1 + 1) begin
serpistirici_A_1[serpistirici_k_1] = veri[serpistirici_k_1];
end
//Oluþturulan ara matris yardýmýyla serpiþtirilmiþ veriyi bulma
for(serpistirici_t_0_1 = 0; serpistirici_t_0_1 <= 3; serpistirici_t_0_1 = serpistirici_t_0_1 + 1) begin
serpistirici_cast_1[serpistirici_t_0_1] = {{30{serpistirici_t_0_1[31]}}, {serpistirici_t_0_1, 2'b00}};
serpistirilmis_veri[serpistirici_t_0_1] = serpistirici_A_1[serpistirici_cast_1[serpistirici_t_0_1]];
end
for(serpistirici_t_1_1 = 0; serpistirici_t_1_1 <= 3; serpistirici_t_1_1 = serpistirici_t_1_1 + 1) begin
serpistirici_add_cast_2[serpistirici_t_1_1] = {{30{serpistirici_t_1_1[31]}}, {serpistirici_t_1_1, 2'b00}};
serpistirilmis_veri[serpistirici_t_1_1 + 4] = serpistirici_A_1[1 + serpistirici_add_cast_2[serpistirici_t_1_1]];
end
for(serpistirici_t_2_1 = 0; serpistirici_t_2_1 <= 3; serpistirici_t_2_1 = serpistirici_t_2_1 + 1) begin
serpistirici_add_cast_0_1[serpistirici_t_2_1] = {{30{serpistirici_t_2_1[31]}}, {serpistirici_t_2_1, 2'b00}};
serpistirilmis_veri[serpistirici_t_2_1 + 8] = serpistirici_A_1[2 + serpistirici_add_cast_0_1[serpistirici_t_2_1]];
end
for(serpistirici_t_3_1 = 0; serpistirici_t_3_1 <= 3; serpistirici_t_3_1 = serpistirici_t_3_1 + 1) begin
serpistirici_add_cast_1_1[serpistirici_t_3_1] = {{30{serpistirici_t_3_1[31]}}, {serpistirici_t_3_1, 2'b00}};
serpistirilmis_veri[serpistirici_t_3_1 + 12] = serpistirici_A_1[3 + serpistirici_add_cast_1_1[serpistirici_t_3_1]];
end
end
assign serpistirilmis_veri_0 = serpistirilmis_veri[0];
assign serpistirilmis_veri_1 = serpistirilmis_veri[1];
assign serpistirilmis_veri_2 = serpistirilmis_veri[2];
assign serpistirilmis_veri_3 = serpistirilmis_veri[3];
assign serpistirilmis_veri_4 = serpistirilmis_veri[4];
assign serpistirilmis_veri_5 = serpistirilmis_veri[5];
assign serpistirilmis_veri_6 = serpistirilmis_veri[6];
assign serpistirilmis_veri_7 = serpistirilmis_veri[7];
assign serpistirilmis_veri_8 = serpistirilmis_veri[8];
assign serpistirilmis_veri_9 = serpistirilmis_veri[9];
assign serpistirilmis_veri_10 = serpistirilmis_veri[10];
assign serpistirilmis_veri_11 = serpistirilmis_veri[11];
assign serpistirilmis_veri_12 = serpistirilmis_veri[12];
assign serpistirilmis_veri_13 = serpistirilmis_veri[13];
assign serpistirilmis_veri_14 = serpistirilmis_veri[14];
assign serpistirilmis_veri_15 = serpistirilmis_veri[15];
assign ce_out = clk_enable;
endmodule
