Verilog FPGA Music Box Problem (Xilinx Spartan 3E)
BeatrixBelle
Newbie level 1
Newbie level 1
Hello,
I am trying to create a finite-state machine design to turn an FPGA development board into a simple programmable music box.
The system should be able to generate melodies, i.e., a sequence of notes. Notes can be selected
from a bank of 16 possible sounds: 15 notes and a pause (no sound).
The following is my code to produce a simple blip sound of a specific note:
module level1(
input wire clk,
input wire [3:0]note,
input wire  reset,
output reg speaker,
output reg [3:0]note_leds
// Binary counter, 16-bits wide
reg [15:0] counter;
initial
begin
counter =0;
end
always @(posedge clk) counter <= counter+1;
reg[15:0]frequency;
always @*
begin
	case(note)
		  1: begin frequency = 381679; note_leds = 4'b0001; end   //C1
        2:  begin frequency = 340136; note_leds = 4'b0010; end   //D1
        3:  begin frequency = 303030; note_leds = 4'b0011; end   //E1
        4:  begin frequency = 285714; note_leds = 4'b0100; end   //F1
        5:  begin frequency = 255102; note_leds = 4'b0101; end   //G1
        6:  begin frequency = 227272; note_leds = 4'b0110; end   //A1
        7:  begin frequency = 202429; note_leds = 4'b0111; end   //B1
        8:  begin frequency = 190839; note_leds = 4'b1000; end   //C2
        9:  begin frequency = 170068; note_leds = 4'b1001; end   //D2
        10: begin frequency = 151515; note_leds = 4'b1010; end   //E2
        11: begin frequency = 143266; note_leds = 4'b1011; end   //F2
        12: begin frequency = 127551; note_leds = 4'b1100; end   //G2
		  13: begin frequency = 113636; note_leds = 4'b1101; end   //A2
        14: begin frequency = 101214; note_leds = 4'b1110; end   //B2
        15: begin frequency = 95602; note_leds = 4'b1111; end   //C3
    default: begin frequency = 1;   note_leds = 4'b0000; end   //nothing
    endcase
end
reg count_freq;
reg [15:0]count;
    count_freq <= (count == frequency);
begin
    if(count_freq | reset)
        count <= 0;
    else
        count <= count + 1'b1;
end
// Use the highest bit of the counter (MSB) to drive the speaker
	 if(reset)
        speaker <= 0;
    else if(count_freq) speaker <= speaker ^ 1'b1;
	 //else speaker <= speaker; //(not required in sequential logic)
endmodule
However, now I need to enable my system to play a melopody based on a given sequence of notes. I will need to create a module which can be initialised to contain the desired sequence of notes. Upon pressure of a push button, these notes will be read by the machine and played through the speaker. Notes should be played such that each note is sounded for 0.6 seconds followed by a 0.2 second period of silence.
The following is the code I have so far. I am using two clocks, the enable function.... however I am really stuck and any help would be very much appreciated:
module melody (
input wire clk,
input wire  reset,
input wire enable
output reg speaker,
reg [17:0] counter;
reg [7:0] sequence;
reg [17:0] nte;
parameter C1 = 190839, D1 = 170068, E1 = 151515,   // these are the notes that will be played
		  F1 = 142857, G1 = 127551, A1 = 113636,
		  B1 = 101214, C2 = 95419,  D2 = 85034,
		  E2 = 75757,  F2 = 71633,  G2 = 63775,
		  A2 = 56818,  B2 = 50607,  C3 = 47801,
		  silence = 0;
initial
begin
counter =0;
end
always @(posedge clk) counter <= counter+1; //setting the counter
always @ (posedge clk)
case(sequence)//inputing the sequence of notes
	1: nte = C2;
	2: nte = D2;
	3: nte = E2;
	4: nte = C2;
	5: nte = C2;
	6: nte = D2;
	7: nte = E2;
	8: nte = C2;
	9: nte = E2;
	10: nte = F2;
	11: nte = G2;
	12: nte = silence;
	13: nte = E2;
	14: nte = F2;
	15: nte = G2;
	16: nte = silence;
	17: nte = G2;
	18: nte = A2;
	19: nte = G2;
	20: nte = F2;
	21: nte = E2;
	22: nte = silence;
	23: nte = C2;
	24: nte = silence;
	25: nte = G2;
	26: nte = A2;
	27: nte = G2;
	28: nte = F2;
	29: nte = E2;
	30: nte = silence;
	31: nte = C2;
	32: nte = silence;
	33: nte = D2;
	34: nte = silence;
	35: nte = G1;
	36: nte = silence;
	37: nte = C2;
	39: nte = silence;
	40: nte = D2;
	41: nte = silence;
	42: nte = G1;
	43: nte = silence;
	44: nte = C2;
	45: nte = silence;
	default: div=silence;
endcase
reg [15:0]count;
    speaker <= (count == frequency);
begin //this is to play the notes after eachother
    if(reset)
        sequence <= 0;
    else
        sequence <= sequence + 1'b1;
		//keeps moving to the next note
begin COUNTER //block using clock and enable to get each note to be played for 0.6 seconds and paused for 0.2
if (reset == 1'b1) begin
	speaker <= #1 4'b0000
end
elseif (enable == 1'b1) begin
	speaker <= #1 speaker + 1;
end
end
end
