Milruwan
Member level 1
- Joined
- Jan 20, 2013
- Messages
- 35
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,546
I design a filter using Matlab hdl coder. But the problem is filter doesn't give filtered output. When I do the simulation in matlab filter works perfectly, but when I test with modelsim filter is not giving the filtered output. Problem is with the way of resetting and enabling the filter.
filter inputs and outputs
input_reg_process
Here is the output I got (reset and enable signal are also shown in the figure)
reset_my : is the reset
ce_my: is the enable
module filter
clk,
clk_enable,
reset,
filter_in,
filter_out
input_reg_process
always @ (posedge clk or posedge reset)
begin: input_reg_process
if (reset == 1'b1) begin
input_register <= 0;
end
else begin
if (clk_enable == 1'b1) begin
input_register <= filter_in;
end
end
end // input_reg_process
