[SOLVED] [Verilog] Data is not transferred from one register to another
ipunished
Junior Member level 3
United Kingdom
I have instantiated a stopwatch module into this multiplexer module. The stopwatch is working as it is supposed to and is producing the expected output. This is also picked up by the instantiated registers, but if I want to use this data further down the module, it does not work.
For example, here is the simulation showing my problem:
So the the values picked up from the stopwatch module are working perfectly. These values are then transferred to the registers ``regd0, regd1, regd2, regd3`` which, instead of displaying the values are displaying ``0``?
Here is the code that produced the above simulation:
        module muxer(
        input clock,
        input reset,
        input [1:0] select,
        output a,
        output b,
        output c,
        output d,
        output e,
        output f,
        output g,
        output dp,
        output [3:0] an
    reg go_hi, go_start;
    wire[3:0] wire_d0, wire_d1, wire_d2, wire_d3; // timer registers that will hold the individual counts
    wire[3:0] wire_hd0, wire_hd1, wire_hd2, wire_hd3; //regsiters to hold the "hi" values
    reg [3:0] regd0, regd1, regd2, regd3; //registers for LED multiplexing
    //instantiate the "hi" module
    say_hi sayhi(.clock(clock), .reset(reset), .go(go_hi), .hi_d0(wire_hd0), .hi_d1(wire_hd1), .hi_d2(wire_hd2), .hi_d3(wire_hd3)) ;
    //instantiate the stopwatch module
    stopwatch timer(.clock(clock), .reset(reset), .start(go_start), .d0(wire_d0), .d1(wire_d1), .d2(wire_d2), .d3(wire_d3) );
    always @ (select)
    begin
    	case(select)
    		00: //hi
    		begin
    			go_start = 0; //make sure timer module is off
    			go_hi = 1'b1; //enable go signal to display "hi"
    			regd0 = wire_hd0; //transfer values to the multiplexing circuit
    			regd1 = wire_hd1;
    			regd2 = wire_hd2;
    			regd3 = wire_hd3;
    		end
    		01: //timer
    		begin
    			go_hi = 0; //make sure "hi" module is off
    			go_start = 1'b1; //enable start signal to start timer
    			regd0 = wire_d0;
    			regd1 = wire_d1;
    			regd2 = wire_d2;
    			regd3 = wire_d3;
    		end
    		10: //stop timer
    		begin
    			go_hi = 0;
    			go_start = 1'b0;
    		end
    	endcase
    end
    //The Circuit for 7 Segment Multiplexing -
    localparam N = 8; //18 for implementation, 8 for simulation
    reg [N-1:0]count;
    always @ (posedge clock or posedge reset)
    	begin
    		if (reset)
    			count <= 0;
    		else
    			count <= count + 1;
    	end
    reg [6:0]sseg;
    reg [3:0]an_temp;
    reg reg_dp;
    always @ (*)
    	begin
    		case(count[N-1:N-2])
    			2'b00 :
    				begin
    					sseg = regd0;
    					an_temp = 4'b1110;
    					reg_dp = 1'b1;
    				end
    			2'b01:
    				begin
    					sseg = regd1;
    					an_temp = 4'b1101;
    					reg_dp = 1'b0;
    				end
    			2'b10:
    				begin
    					sseg = regd2;
    					an_temp = 4'b1011;
    					reg_dp = 1'b1;
    				end
    			2'b11:
    				begin
    					sseg = regd3;
    					an_temp = 4'b0111;
    					reg_dp = 1'b0;
    				end
    		endcase
    	end
    assign an = an_temp;
    reg [6:0] sseg_temp;
    always @ (*)
    	begin
    		case(sseg)
    			4'd0 : sseg_temp = 7'b1000000; //display 0
    			4'd1 : sseg_temp = 7'b1111001; //display 1
    			4'd2 : sseg_temp = 7'b0100100;// display 2
    			4'd3 : sseg_temp = 7'b0110000;
    			4'd4 : sseg_temp = 7'b0011001;
    			4'd5 : sseg_temp = 7'b0010010;
    			4'd6 : sseg_temp = 7'b0000010;
    			4'd7 : sseg_temp = 7'b1111000;
    			4'd8 : sseg_temp = 7'b0000000;
    			4'd9 : sseg_temp = 7'b0010000;
    			4'd10 : sseg_temp = 7'b0001001; //to display H
    			4'd11 : sseg_temp = 7'b0000111; //to display I
    			default : sseg_temp = 7'b0111111; //dash
    		endcase
    	end
    assign {g, f, e, d, c, b, a} = sseg_temp;
    assign dp = reg_dp;
    endmodule
Presumed select is constantly 2'b01, regdx won't be updated in simulation, because no update event is trigerred. Case 10 (decimal 10) is outside the range of the 2-bit variable select. I guess you meaned to write 2'b10.
Thanks for the reply. But even in case 00, the registers regdx are not updated. And in the simulation I have shown the select signal is set at 01. I don't think it's a range issue
