I want to read the out value with the condition when the Trigger signal (Trig_SG) is high. I have tried with below code but i didnt got proper output. Please suggest me.
module Trigger_RTC
input clk_50,
//output Trig_SG,
output reg Final_out
reg out;
reg Trig_SG=1'b0;
always@(posedge clk_50)
begin
Trig_SG<=1'b1;
if(Trig_SG==1'b1)
begin
out<=out+1;
Final_out<=out;
end
else
Final_out<=0;
end
endmodule
What do you expect as "proper output"? According to your code, Trig_SG will be activated at the first clock edge after power on reset and stay permanently on. You should see this in a simulation.
Where is the source of the Trig_SG and "out value" signals? Are they from external module/pin or driven internally inside Trigger_RTC module?
Please give us more context about the function of this block. What do you want to do and what is the vicinity?
You want to read the "out value", but the "out value" is not an input for this module. Also Trig_SG is not an input - so it is confusing.
