8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
| `timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 19:18:28 09/24/2016
// Design Name:
// Module Name: SDIO_M
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module SDIO_M(
input clk,
input [7:0] din,
input reset,
input dm_in,
input wr,
input rd,
input miso,
output reg mosi,
output reg cs,
output reg sclk,
output reg [7:0] dout
parameter [4:0] rst=5'd0,
init=5'd1,
cmd0=5'd2,
cmd55=5'd3,
cmd41=5'd4,
poll_cmd=5'd5,
idle=5'd6,
read_block=5'd7,
read_block_wait=5'd8,
read_block_data=5'd9,
read_block_crc=5'd10,
send_cmd=5'd11,
receive_byte_wait=5'd12,
receive_byte=5'd13,
write_block_cmd=5'd14,
write_block_init=5'd15,
write_block_data=5'd16,
write_block_byte=5'd17,
write_block_wait=5'd18;
reg [4:0] state,return_state;
integer byte_counter=515;
integer bit_counter=160;
reg sclk_sig;
reg [55:0] cmd_out;
reg [7:0] recv_data;
reg [31:0] address;
reg cmd_mode=1;
reg data_mode=1;
reg response_mode=1;
reg [7:0] data_sig=8'h00;
always @(posedge clk or reset)
begin
data_mode<=dm_in;
if(reset)
begin
state<=rst;
sclk_sig<=0;
end
else begin
case(state)
rst:begin
sclk_sig<=0;
cmd_out<=0;
address<=0;
byte_counter=0;
cmd_mode<=1;
response_mode<=1;
bit_counter=160;
cs<=1;
state<=init;
end
init:begin
if(bit_counter==0)
begin
cs<=0;
state<=cmd0;
end
else begin
bit_counter<=bit_counter-1;
sclk_sig<=~sclk_sig;
end
end
cmd0:begin
cmd_out<=56'hff400000000095;
bit_counter<=55;
return_state<=cmd55;
state<=send_cmd;
end
cmd55:begin
cmd_out<=56'hff770000000001;
bit_counter<=55;
return_state<=cmd41;
state<=send_cmd;
end
cmd41:begin
cmd_out<=56'hff690000000001;
bit_counter<=55;
return_state<=poll_cmd;
state<=send_cmd;
end
poll_cmd:begin
if(recv_data[0]==1'b0)
begin
state<=idle;
end
else begin
state<=cmd55;
end
idle:begin
if(rd)
begin
state<=read_block;
end
else if(wr)
begin
state<=write_block_cmd;
end
else begin
state<=idle;
end
end
read_block:begin
cmd_out<={8'hff,8'h51,address,8'hff};
bit_counter<=55;
return_state<=read_block_wait;
state<=send_cmd;
end
read_block_wait:begin
if(sclk_sig && !miso)
begin
state<=read_block_data;
byte_counter<=511;
bit_counter<=7;
return_state<=read_block_data;
state<=receive_byte;
end
sclk_sig<=~ sclk_sig;
end
read_block_data:begin
if(byte_counter==0)
begin
bit_counter<=7;
return_state<=read_block_crc;
end
else begin
byte_counter<=byte_counter-1;
bit_counter<=7;
end
end
read_block_crc:begin
bit_counter<=7;
return_state<=idle;
address<=address+12'h200;
end
send_cmd: begin
if(sclk_clk)
begin
if(bit_counter==0)
begin
state<=receive_byte_wait;
end
else begin
cmd_out<={cmd_out[54:0],1'b1};
end
end
end
receive_byte_wait:begin
if(sclk_sig)
begin
if(!miso)
begin
recv_data<=8'h00;
end
end
if(!response_mode)
begin
bit_counter<=3;
end
else begin
bit_counter<=6;
end
end
receive_byte: begin
if(sclk_sig)
begin
recv_data<={recv_data[6:0],miso};
end
if(bit_counter==0)
begin
state<=return_state;
dout<={recv_data[6:0],miso};
end
else begin
end
end
write_block_cmd:begin
cmd_mode<=1;
if(!data_mode)
begin
cmd_out<={8'hff,8'h59,address,8'hff};
end
else begin
cmd_out<={8'hff,8'h58,address,8'hff};
end
bit_counter<=55;
return_state<=write_block_init;
state<=send_cmd;
end
write_block_init:begin
cmd_mode<=0;
byte_counter<=515;
state<=write_block_data;
end
write_block_data: begin
if(byte_counter==0)
begin
return_state<=write_block_wait;
response_mode<=0;
end
// else begin
if(byte_counter==2 or byte_counter==1)
begin
data_sig<=8'hff;
end
// else begin
if(byte_counter==515)
begin
if(!data_mode)
begin
data_sig<=8'hfc;
end
else begin
data_sig<=8'hfe;
end
end
// end
// end
else begin
data_sig<=din;
end
bit_counter<=7;
end
write_block_byte: begin
if(sclk_sig)
begin
if(bit_counter==0)
begin
end
else begin
data_sig<={data_sig[6:0],1'b1};
end
end
end
write_block_wait:begin
response_mode<=1;
if(sclk_sig)
begin
if(miso)
begin
if(!data_mode)
begin
end
end
end
else begin
state<=idle;
end
// end
// end
end
// default: begin
// state<=idle;
// end
endcase
end
end
assign sclk=sclk_sig;
assign mosi=(cmd_mode)?cmd_out[55]:data_sig[7];
endmodule
$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$4 |
