module Input(
input Clk,
input RxD,
output [31:0]FreqW,
output [31:0]PW,
output [31:0]PW2,
output [31:0]Delay,
output [31:0]Delay2
//Parameter Declaration. //
parameter Increment1K=42949;
parameter Increment1M=42949672;
parameter IDLE=6'b000001;
parameter ADR =6'b000010;
parameter D0 =6'b000100;
parameter D1 =6'b001000;
parameter D2 =6'b010000;
parameter D3 =6'b100000;
//Reg and Wire Declaration. //
reg [31:0]FrequencyWord=Increment1M*2;
reg [31:0]Pulse_Width=25;
reg [31:0]Pulse_Width2;
reg [31:0]Delay_Hold=32'h00000005;
reg [31:0]Delay_Hold2;
reg [31:0]Data;
//Byte Counter.
reg [5:0]ByteCounter;
//Data Edge Detector
reg [1:0]DataRdy;
wire DataReady;
//Decoded Address
reg [7:0]Addr;
//UART Wires.
wire RxD_data_ready;
wire [7:0]RxD_data;
wire Baud_Clk;
//USART Receiver and Decoder. //
// Instantiate the module
u_rec Receiver (
.sys_rst_l(1),
.sys_clk(Baud_Clk),
.uart_dataH(RxD),
.rec_dataH(RxD_data),
.rec_readyH(RxD_data_ready)
baud Baud_Generator (
.sys_clk(Clk),
.sys_rst_l(1),
.baud_clk(Baud_Clk)
//Data Decoder or Parser //
//Shift Register to store if Data Ready State.
always@(posedge Clk)
DataRdy <= {DataRdy[0],RxD_data_ready};
//Data Availability Bit.
assign DataReady = (DataRdy == 2'b01) ? 1'b1 : 1'b0;
begin
if(DataReady)
begin
case(ByteCounter)
IDLE: ByteCounter = ADR;
ADR : ByteCounter = D0;
D0 : ByteCounter = D1;
D1 : ByteCounter = D2;
D2 : ByteCounter = D3;
D3 : ByteCounter = IDLE;
default:ByteCounter = IDLE;
endcase
end
end
begin
if(ByteCounter == ADR)
Addr = RxD_data;
else if(ByteCounter == D0)
Data = {Data[31:8],RxD_data};
else if(ByteCounter == D1)
Data = {Data[31:16],RxD_data,Data[7:0]};
else if(ByteCounter == D2)
Data = {Data[31:24],RxD_data,Data[15:0]};
else if(ByteCounter == D3)
Data = {RxD_data,Data[23:0]};
end
begin
case(Addr)
8'h41:FrequencyWord = Data;
8'h42:Pulse_Width = Data;
8'h43:Pulse_Width2 = Data;
8'h44:Delay_Hold = Data;
8'h45:Delay_Hold2 = Data;
default:FrequencyWord = FrequencyWord;
endcase
end
assign FreqW = FrequencyWord;
assign PW = Pulse_Width;
assign PW2 = Pulse_Width2;
assign Delay = Delay_Hold;
assign Delay2= Delay_Hold2;
endmodule
