kbm10
Junior Member level 3
I am a newb in analog desing .
I have to design a circuit using an opamp which amplifies an input signal(0-5V) to upto (0-12V). I am using an opamp for the same. I have a single rail supply (0-24V). The problem is I have to split the rails first before I can use it with an opamp. Is it possible to split the rails to +ve/-ve rails(-12 to +12) using OPAMPs ?
Can anyone suggest some circuit which uses OPAMP for the same and give a brief explation ?
