el_coronel
Junior Member level 1
Dear colleagues,
Recently I design in AWR MWO two types of X-band VCO using BFR840 transistor: with common emitter and common collector.
I always used to thought that CE circuit provides a higher value of output power than other ones. But I see the reverse situation: while CC circuit gives about 7 dBm of output power, CE scheme gives something around -10 and less dBm.
The CE is more preferable due to the transistor topology.
Would someone explain, please, what causes such a big power decrement while changing CC to CE?
Not being a big specialist in active devices simulation, may be I'm doing something wrong?
You could find the archived project file attached.
