Mar 24, 2009 #1 O omar-malek Member level 5 Joined Mar 24, 2007 Messages 89 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Location French Activity points 1,949 VCC of pic 18 =3.3 V? i need interface pic 18F452 with xbee module but i find probleme of interface betwen xbee and pic if possible make VCC+3.3V for the pic question: he stille working with3.3V or any one give solution for this problem please now i'am in the last month of my final project. thank you for all
Mar 25, 2009 #2 randell_xtian Full Member level 4 Joined Mar 25, 2008 Messages 199 Helped 28 Reputation 56 Reaction score 14 Trophy points 1,298 Location Philippines Activity points 2,667 Re: VCC of pic 18 =3.3 V? Hi, The operating voltage of the PIC18F452 is 2 to 5.5V's. normally, the microcontroller operates at the 5V, when we supply 3.3V to the uc, it will still operate depend on what type of application is. just read its DataSheet... Best Regards, Randell_xtian
Mar 25, 2009 #3 F fastpcbcenter Newbie level 4 Joined Mar 25, 2009 Messages 5 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Activity points 1,366 VCC of pic 18 =3.3 V? PIC MCU will still work in 3.3V voltage. maybe a MOS switch between POWER and MCU, set shutoff voltage = 3.3V.
Apr 1, 2009 #4 S shashavali_m Member level 4 Joined Apr 18, 2005 Messages 70 Helped 1 Reputation 2 Reaction score 0 Trophy points 6 Activity points 0 VCC of pic 18 =3.3 V? PIC works from 2.4V to 5.5V, so it should work for 3.3V. Check the Brown Out reset configuration bits in the configuration registers if it resets. Change the brown out reset to 2V.
