I thank you for the reply. I tried the following to simulate a cache with eight sets.
module cl(index, r, clk, out);
input [2:0] index;
input [287:0] r;
input clk;
output out;
reg [287:0] out;
reg [2:0] temp;
always @(posedge clk)
begin
out = 0;
end
always @(negedge clk)
begin
out = r;
end
endmodule
module fa_generate(address, d, clk, l1hits);
input [31:0] address;
input [31:0] d;
output l1hits;
input clk;
reg [15:0] l1hits;
reg [2:0] temp;
wire [287:0] out[7:0];
generate
genvar j;
for (j=0; j<8; j=j+1)
begin:B1
cl c (j, d, clk, out[j]);
end
endgenerate
endmodule
I was able to synthesize the code. However I was unable to complete the Implement Design option in xilinx tool. I get the following error.
Section 1 - Errors
ERROR
ack:198 - NCD was not produced. All logic was removed from design. This
is usually due to having no input or output PAD connections in the design and
no nets or symbols marked as 'SAVE'. You can either add PADs or 'SAVE'
attributes to the design, or run 'map -u' to disable logic trimming in the
mapper.
I tried the -u option but the error still exists. could you please let me know what I am missing?
