Variable 200 A/ 100 V Variable Electronic Load
jzaghal
Full Member level 2
Full Member level 2
Need to test electronic welding machines.
Any hints.
Thanks.
Please don't reply unless you have useful information to add on this post.Thanks
Come on guys/gals. It must use few paralleled N-Channel Mosfets.
I have seen a circuit for light loads in
one of the Elektor 300 circuit books ???
I think you could use an application note at h**p://www.advancedpower.com/TechnicalSupport/ApplicationNotesIndex.asp. It is the APT0002. It uses paralled MOSFETs in an improved circuit and makes a 120kW load with them.
I have not seen the Elektor circuit you refer red to.
Regards, unkarc
A good beginning thanks.
I am referring to the book 301 circuits,
on page 285 Variable power resistor.
Thanks.
Use big salt water tank.
You can change the load characterictic distance between the electrodes.
LaTeX Commands Quick-Menu:
