UWB antenna design needed
pepino
Junior Member level 1
17. johnna_sm_2004.pdf
Does anybody has UWB (3.1-6 GHz) antenna design, with ground plane. I need radiation in only the half of the space.
Thank you in advance!
Thank you for the link, m8t! But all antennas inside are not over ground plane (exept the 3-D monopoles ). They must stand away from the ground plane to work. Actually I need a model over ground plane. Something like p@tch antenna with wery wide BW
