UVM Sequencer with a transfer function
Yankie
Is it possible to have a UVM sequencer that takes an object from UVM sequence and sends only a subset of the object to the driver?
E.g
class RECT extends uvm_sequence_item;
int length, breadth, area, perimeter;
endclass
class CIR
int radius;
endclass
class driver extends uvm_driver #(CIR);
seq_item_port.get_next_item(req);
seq_item_port.item_done();
endclass
Is it possible to have a sequencer that would take object of class RECT, copy it's data in to CIR object and then send this CIR object to driver?
class seqr extends uvm_sequence #(RECT);
CIR obj_CIR;
virtual task body()
obj_CIR = new();
`uvm_create_on(req, m_sequencer);
obj_CIR = req.length;
start_item(obj_CIR);
finish_item(obj_CIR);
endtask
endclass
Thanks !!
Yankie,
This is typical of any layered protocol. You can do what you want with the following corrections
obj_CIR = CIR::type_id::create("circle");
req = RECT::type_id::create("rectangle");
if (req.randomize())  else `uvm_fatal(<some message>);
obj_CIR.radius = req.length;
You should always construct your classes with the create method instead of new() so the test can make overrides later.
`uvm_create_on(req, m_sequencer); is the same as `uvm_create(req);, but I don't recommend ever using the sequence macros. There are too many different flavors, and it is hard to read the code unless you memorize all of them.
You probably did not remember that `uvm_create does not randomize the item.
If your sequences are much more complicated that what you have shown, you may want to look at https://verificationacademy.com/cookbook/Sequences/Layering
