This sounds like the compiler (GCC or whatever) was not properly installed : (
You might need to check, maybe gcc -print-search-dirs or some other command (type gcc --help).
If the features.h was your own header file that you included (and not a standard header file that
came with your compiler), then you need to debug using the normal procedures, i.e. check where your
predefs.h file is placed.
