Using USI-SPI on Attiny 4313 to receive data from Attiny24A
firstoption
Newbie level 6
Newbie level 6
Dear Sir/Ma,
Please I need your Support.I am not too sure if this Kind of configuration is possible.I am trying to use the Usi-Spi of Attiny4313(as Master)to receive DATA from Attiny24A(Slave).I am using the GPIO PINs of Attiny24A to send the DATA to the Master.I have already tried this configuration on a breadboard but instead of 4 LEDs ON and 4 LEDs OFF,all my Output Leds were blinking then after sometime all LEDs went OFF except one LED.Below are my lines of code and Pin Configuration.Both Master and Slave are runing @1MHz System clock.
PIN CONFIGURATION
ATTINY4313-------------------ATTINY24A
PB5/DATA_IN-----------------DATA_OUT/PB1
PB6/DATA_OUT----------------DATA_IN/PA1
PB7/USCK--------------------CLK_IN/PA7
//USI-SPI MASTER CODE
 #include <avr/io.h>
 #include <avr/delay.h>
 //#include <avr/iotn2313.h>
  #define CTRL_PORT   DDRB
  #define DATA_PORT   PORTB
  #define CLK_PIN     PORTB7
  #define DI_PIN      PORTB5
  #define DO_PIN      PORTB6
  //USI-SPI master
  void init()
     //Configure outputs
     CTRL_PORT |= ( 1<<DO_PIN) | (1<< CLK_PIN);
  unsigned char Transmit(unsigned char data)
     //Load data
     USIDR = data;
     //Clear the USI counter overflow flag
     USISR = (1<< USIOIF);
     do
     USICR = (1<< USIWM0) | (1<< USICLK) | (1<< USICS1) | (1<< USITC);
     } while((USISR & (1<< USIOIF)) == 0);
     return USIDR;
  int main(void)
      DDRD |= 0xFF; //Led Output
      unsigned char  dummy_value =20;
      init();
     while(1)
          PORTD =  Transmit(dummy_value);
//USI-SPI SLAVE CODE
 #include <avr/io.h>
 #include <avr/interrupt.h>
  ClearClock()
    PORTA &= ~(1 << PINA7);  // Clear
 void SetClock()
    PORTA |= (1 << PINA7);   // Set
 void ToggleClock()
    SetClock();
    ClearClock();
 void SetData()
    PORTB |= (1 << PINB1);   // Clear
 void ClearData()
    PORTB &= ~(1 << PINB1);  // Set
 void send_8Bit(unsigned int data10)
    int i=7;
    do
       if (((data10 & (1<<i))>>i) == 1)
       SetData();
       else
       ClearData();
       ToggleClock();
       i=i-1;
    while (i >= 0);
 int main(void)
    unsigned int  data;
    DDRA |=0b01111111;
    DDRB |=(1<<PINB1);
    data =0b01010101;
 while(1)
      send_8Bit(data);
NOTE:The USART and I2C on both Attiny4313 and Attiny24A are already in use.I am using USART on Attiny4313 to send DATA to the PC and the I2C on Attiny24A to read Temperature from a Temperature-Sensor.So I am somehow left with USI-SPI and GPIO PINs for communication between the Master and the slave.Sir I would be very grateful if you could put me through on how to adjust these codes in order to get the desired output
Thank you for the Support.Best regards.
Osanyinpeju.
